Removing powder coat #122566
09/18/08 09:16 AM
09/18/08 09:16 AM
PA
BS27ROB Offline OP
BS27ROB  Offline OP
PA
Is there any way to remove powder coat without marring the substrate? How would the part have likely been prepared for coating? This is on a master cylinder. Do you think it could be returned to an original appearance?
Re: Removing powder coat [Re: BS27ROB] #122567
09/18/08 10:15 AM
09/18/08 10:15 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Regular old paint stripper works fine
Re: Removing powder coat [Re: ScottSmith_Harms] #122568
09/18/08 10:40 AM
09/18/08 10:40 AM
I've had good luck with Tal-Strip aerosol paint remover.Usually find it a Checker/Cragens/Shuckers.
Re: Removing powder coat [Re: BS27ROB] #122569
09/19/08 11:22 AM
09/19/08 11:22 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Hot tank.
As long as the part was clean it would have needed nothing else prior to powder coating. The powder isn't that thick so if you don't see casting lines or the rough as-cast finish then it's likely been touched up before it was coated.
