Question for the board from a newbie. #1224418
04/29/12 07:30 PM
04/29/12 07:30 PM
arizona
azsuperbee Offline OP
arizona
What size light bulbs go in a 1969 Coronet Fender Signal Indicator and do you take it off from the top or bottom to replace the light bulb? Thanks guys.
Re: Question for the board from a newbie. [Re: azsuperbee] #1224419
04/29/12 07:34 PM
04/29/12 07:34 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
are you talking about the optional lights on top of the fender? if so it a ge 300 (recently discussed here, 14 volt is fine) and i believe the plastic lens unscrews from the housing.
Re: Question for the board from a newbie. [Re: mikemee1331] #1224420
04/29/12 07:37 PM
04/29/12 07:37 PM
arizona
arizona
Yes I am talking about the optional lights on top at the frong of each fender. So they unsrew off. I was trying to pull them off. I will try that. I thought I already did. They have probably never been removed and I can only imagine the rust, corrosion and dirt and grease cementing them together.
Re: Question for the board from a newbie. [Re: azsuperbee] #1224421
04/29/12 07:44 PM
04/29/12 07:44 PM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
With those bullet style chrome fender mount turn signal indicators you have to been really careful if you are going to unscrew the yellow lenses. Some have a slot and some do not and if they're original they are old, fragile, and break easy. If you remove the entire chrome bullet with the two bolts underneath the inside of the fender it can be easier to get to the bulb. There is an allen set screw on the bottom side behind the rubber gasket on the bullet mount istelf. If you loosen that set screw, the entire socket/bulb assembly, wiring and amber lens attached will pull through the front of the chrome bullet housing. I believe the bulb is a Wagner 550. It's kind of a hassle. But if you don't have extra amber lenses laying around, it may save you from buying one if you break the original.
The GTS Registry!
MOPARTS MEMBER IN PRINT
1969 Dart GTS LS23P9B (First day of production car money pit)
Re: Question for the board from a newbie. [Re: azsuperbee] #1224422
04/29/12 07:49 PM
04/29/12 07:49 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
oh yeah, welcome aboard (didn't mean to be rude
Re: Question for the board from a newbie. [Re: azsuperbee] #1224423
04/29/12 07:53 PM
04/29/12 07:53 PM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
Welcome! Nice way to get started by a good legit Mopar question! Where are you from and what kind of Mopar(s) do you have or are working on?
The GTS Registry!
Re: Question for the board from a newbie. [Re: JOES4FORTY] #1224424
05/29/12 09:00 PM
05/29/12 09:00 PM
arizona
arizona
Thanks for all the nice welcome to the board posts. This board is not only very informative but also very friendly! I live in Arizona but am originally from back east. I have had 2 68 chargers, two 69 chargers and now a 69 super a12 clone.
Another quick question. Can you guys tell me what size light bulb for the trunk light? Anyone with a 1969 Dodge Coronet or Superbee. Thanks again guys. Mopars Forever!
Re: Question for the board from a newbie. [Re: azsuperbee] #1224425
05/29/12 09:49 PM
05/29/12 09:49 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
