Front suspension on Ebay, what do you think? #1224133
04/29/12 11:02 AM
04/29/12 11:02 AM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
I have been thinking about upgrading the front end of my 70 Barracuda. I was looking into other complete front ends but the cost is out of my budget. Does anyone have any experience with these front end aftermarket kits.
http://www.ebay.com/itm/Plymouth-Cuda-M2...r#ht_2751wt_804
Ron
Re: Front suspension on Ebay, what do you think? [Re: batt2rm] #1224134
04/29/12 11:47 AM
04/29/12 11:47 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Never heard of them, but I sure wouldn't go that route even if I were looking at aftermarket suspension. That's a weld-in kit.
Unless they can provide information related to the geometry of the system and some real satisfied customers, run away FAST.
As for me and my cars, I will stick with modified Mopar suspension (stiffer t-bars, etc.) to make these cars handle.
Re: Front suspension on Ebay, what do you think? [Re: batt2rm] #1224135
04/30/12 08:45 PM
04/30/12 08:45 PM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
Anyone else.
Re: Front suspension on Ebay, what do you think? [Re: batt2rm] #1224136
04/30/12 09:22 PM
04/30/12 09:22 PM
albemarle, NC
dusterbd13 Offline
dusterbd13  Offline
albemarle, NC
i wouldnt. for a few reasons.
1. ive never had any luck with hilux suspension parts.
2. this appears to be a knockoff of the streetrodder mustang 2 parts. it features a 7 gauge wed in crossmember, with coil spring pockets and tubular control arms. tire clearance appearss as if it will be an issue. and no motor mounts. not to mention your cudas front unibody framerails are nowhere near 7 gauge, which would make me question the integrity of the installation with welding the dissimlar material thicknesses.
3. mustang 2 suspensions are not exactly known for their ultiomate handling characteristics. usually thayre used as an upgrade from what was there, such as solid axles, twin i-beams, etc.
4. its actually heavier than what you have now.
5. this kind of kit, you will be having a TON more fab work than you bargain for, making for a more expensive setup in the long run once you factor in the steering linkage, headers, motor mounts, plumbing mods, and wheel offsets.
hope that helps. id really look into all your options before considering this. much rather see you go with some lower budget hardware that will get you what you want, versus spending money on parts you dont need and headaches you dont expect.
what ARE your goals, after all?
michael
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: Front suspension on Ebay, what do you think? [Re: dusterbd13] #1224137
04/30/12 09:41 PM
04/30/12 09:41 PM
BDW Offline
BDW  Offline
Brakes seem a little weak?
9 inch disc brake rotors
Re: Front suspension on Ebay, what do you think? [Re: BDW] #1224138
04/30/12 10:57 PM
04/30/12 10:57 PM
IN
ahy Offline
ahy  Offline
IN
With a moderate investment in what you have you can get a lot better result. The basic T bar setup is very capable.
1'st step is to assess current condition. If it needs a basic suspension rebuild (bushings, ball joints, tie rod ends ect.) do it. I'd suggest rubber bushings. Next is brakes. If you have discs you are good. If drums, upgrade to disks. The disc upgrade is possible with all used or reman or re-pop factory parts. See Mopar Action Disk-o-Tech. Another option is "scarebird". You can Google them. Next is shocks if they are tired. A good set of parts store gas shocks should be fine for a moderate build. Next step is a bigger sway bar. Finally the alignment. If your alignment guy can get some positive caster (say 2-3 degrees. up to 5 degrees is better) and some negative camber (say -.5 degree) you will feel a big difference. Factory toe settings are fine. With these mods I bet you will say "wow". More is possible but you can see a huge gain from the above without breaking the budget.
I'd add, there is wide variation in quality of suspension parts. I've had good results dealing with Firm Feel. There are other good ones... just be careful.
Re: Front suspension on Ebay, what do you think? [Re: ahy] #1224139
05/01/12 12:23 AM
05/01/12 12:23 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
It looks like a universal kit. I never understood the popularity of the mustang II based suspension kits, that car was never known for strength or stellar handling.
Re: Front suspension on Ebay, what do you think? [Re: batt2rm] #1224140
05/01/12 01:23 AM
05/01/12 01:23 AM
None
71rm23 Offline
71rm23  Offline
None
I wouldnt get one. IMHO, I'd save up enough coin and purchase a kit from a reputable vendor, if thats what your goal is. I just think it would be more of a PITA as far as fitment and the headaches
Re: Front suspension on Ebay, what do you think? [Re: 71rm23] #1224141
05/01/12 01:42 AM
05/01/12 01:42 AM
Middleton, ID
curleysracecars Offline
Middleton, ID
As mentioned, its a basic "generic" Mustang II type front clips. They make them for almost every car out there.
Kyle Curley
Re: Front suspension on Ebay, what do you think? [Re: curleysracecars] #1224142
05/01/12 03:38 AM
05/01/12 03:38 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
......AAAaaaand THpppppt! The OP doesn't get the answer that he wanted, then went away.
What? Are we just supposed to "rubber stamp" all ideas, good and bad?
Jeff
Re: Front suspension on Ebay, what do you think? [Re: Jjs72D] #1224143
05/01/12 09:11 AM
05/01/12 09:11 AM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
Thanks for all the replies guys. I will definitely stay away from that kit. My front suspension it stock and rebuilt with all rubber bushings. I guess I was just wondering if there was anything out there that would make a car handle more like a modern car. My 70 Cuda has a new 6.4 EFI hemi and a Tremec 5 speed in it. I kept the exterior close to stock and the interior stock except new gauges. This is driven on the street and may possible take a trip to the track.
Thanks again.
Re: Front suspension on Ebay, what do you think? [Re: BDW] #1224144
05/01/12 11:47 AM
05/01/12 11:47 AM
Alberta
rustbuckett68 Offline
Alberta
'Rated for 3000 lbs' sound kinda light, which explains the 9" rotors. Good for fairground duty.
Re: Front suspension on Ebay, what do you think? [Re: batt2rm] #1224145
05/01/12 12:06 PM
05/01/12 12:06 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Thanks again.
First and biggest bang for the buck, ditch the stock alignment specs get a radial friendly setting. Radials will tolerate much more aggressive settings that will make a big impact on feel. Go for as much positive caster as possible, -.5 degrees camber and 1/16" inch, or the equivilent degrees of toe in.
After that then you can look at supporting the body better via add ons, upgrading shock control, then maybe better sway bars.
Re: Front suspension on Ebay, what do you think? [Re: batt2rm] #1224146
05/01/12 05:06 PM
05/01/12 05:06 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
Sounds like you've got deep pockets. If so, there's always RMS:
http://www.reillymotorsports.com/
Everything I've ever heard about his products are positive.
vm
Re: Front suspension on Ebay, what do you think? [Re: vynn3] #1224147
05/01/12 05:23 PM
05/01/12 05:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
vm
I'm guessing he doesn't which is why he was looking at that kit .
Re: Front suspension on Ebay, what do you think? [Re: batt2rm] #1224148
05/01/12 09:02 PM
05/01/12 09:02 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Read the article in the latest mopar action about " some " front end set ups like the one pictured. It's hard to beat what the factory came up with.
Re: Front suspension on Ebay, what do you think? [Re: 71birdJ68] #1224149
05/01/12 09:31 PM
05/01/12 09:31 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Before I bought the Charger, I figured that if I ever bought and built a 68-70 Charger, I'd ditch the stock setup and install some kind of "front steer" coil type suspension. After i bought the 70, I looked at the factory setup much closer. I have to agree with Rick E. The factory stuff is a great design, and with a little help from the aftermarket, it can really perform well.
Re: Front suspension on Ebay, what do you think? [Re: Kern Dog] #1224150
05/01/12 09:36 PM
05/01/12 09:36 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Some of us have known that for 35 years....
Re: Front suspension on Ebay, what do you think? [Re: JohnRR] #1224151
05/01/12 10:03 PM
05/01/12 10:03 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Ask
vm
You went through all that trouble to put a 6.4 in and now you want a new front end? Interesting......
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Front suspension on Ebay, what do you think? [Re: Jim_Lusk] #1224152
05/01/12 10:28 PM
05/01/12 10:28 PM
moparx Offline
moparx  Offline
i can offer my personal experiance with a helix kit. they are indeed a "universal" streetrod type of deal. last year, i had the "priviledge"[?] of "fixing" an install of one of those exact kits on a 53 chevy pickup. to start with, the original installer and his "expert fabrication" pal sure had strange ideas when it came to level out the existing chassis and square up everything before starting to hack away. the first thing i did was check out the installation instructions. they are VERY "generic" [even though this kit was SPECIALLY DESIGNED for this installation] and assume you are a fabber with some experiance under your belt as well as having some insight of how a suspension is supposed to operate. next, i releveled and squared up everything. after some serious examination, it was apparent that the crossmember and upper hats needed some serious trimming in order to fit the chassis, even tho this was a "custom designed kit for your application". after a pile of work, it was installed and i made sure there was not any issues as to the function of the unit. however, i had to re-do the rack mounts because there was a horrible amount of bumpsteer - almost 1" ! i got it down to just a little over .250" before giving up. as stated, the brakes are puney and the option i see as being the easiest, would be to change 'em out to granada size[around 11" i think they are], but i don't know what additional cost that would be. also, i discovered the included shocks were not the right length, but i don't remember what they were swapped for. the quality of the kit, in my opinion, is just barely adequate for the intended purpose of getting your car on it's feet. i was REAL GLAD to walk away from this project ! i give this kit 2 . just my opinion and my real world experiance. the op would be further ahead to upgrade his t-bars,shocks, brakes, and steering box. cheaper in the long run by far !
