Re: Final Showdown: traction bars - YES or NO?
[Re: nutso suave]
#1223286
04/27/12 10:49 PM
04/27/12 10:49 PM
Posts: 12,150 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Not no.......but HELL NO!
Springs, shocks, pinion angle, drive height, weight transfer, tire compound, etc, etc.
But not slappers.
And, to be honest, the only thing that pinion snubbers ever did for me was stop the rear U-joint from being twisted out when I had poor rear set-ups way back when.
Master, again and still
[Re: TC@HP2]
#1223288
04/28/12 10:49 PM
04/28/12 10:49 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I get between 4 and 5 inches of lift out of my rear springs. The snubber does not contact the floor.
I certainly don't need slappers.
[Re: TC@HP2]
#1223290
04/29/12 12:14 PM
04/29/12 12:14 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
If your springs a set up properly, the body will seperate from the axle, or rise, and snubber and/or slappers are rendered useless.
Slappers typically hit the leafs just aft of the main eye, right in the weakest part of the spring. If the are doing that, good chance your going to bend your main leaf as it trys to lever the car's body up. Think of it this way, would you use a floor jack in this spot? That's what slappers are doing.
traction bars should be pushed forward up under the leaf spring mount, not under the spring itself.
[Re: Dean_Kuzluzski]
#1223291
04/29/12 12:48 PM
04/29/12 12:48 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
caltracs, the "hi-tech" slapper bar. they do what they are supposed to do. so does the pinion snubber, if your ride isnt jacked to the sky.
[Re: Golden-Arm]
#1223292
04/29/12 01:24 PM
04/29/12 01:24 PM
Posts: 7,863 Colorado
Leadfoot
Colorado
All traction bars do is control any wheel hop issues you may have. Pinion snubbers do the same thing. They keep the pinion from walking up the ring gear. Like this: Traction bars stop it and snubbers stop it. One stops it from the center and one stops it from the outside. The reason traction bars are frowned on in the Mopar ranks is because Mopar sells a snubber. Reason two is that a lot of traction bars are built for Brand X and therefore extend beyond the front shackle. In fact a lot of traction bars are 21 inches or better but the front spring segment is 20 inches for A-Body and as long as 24 inches for the Barges. I believe Mopar Performance also sold clamps for the front spring segments to stiffen the front segment up. So yes. If you're getting wheel hop then traction bars can and will work. The only thing about traction bars is that some of "Those Guys" have been known to twist their housing on launch.
[Re: Supercuda]
#1223295
04/29/12 03:23 PM
04/29/12 03:23 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
Your graphic is bassackwards in direction
You sure about that? It looks like the front of the car would be to the right of the graphic (we're looking at the right side of the car in the diagram), the rear leaf spring shackle is on the left side of the graphic, at the back of the car.. it looks like the tire is rotating clockwise, moving the car forwards... looks correct to me.
[Re: cal_gecko]
#1223296
04/29/12 03:28 PM
04/29/12 03:28 PM
Posts: 2,046 ky.
kenworth_goose
ky.
Wrong! When you look at this picture, the pinion is going towards the ground, that is the opposite of what happens. When you accelerate the pinion will go in the opposite direction, or up.
[Re: nutso suave]
#1223301
05/01/12 09:36 AM
05/01/12 09:36 AM
Posts: 15,487 Florida
scratchnfotraction
I use a south side machine lift bar thats for an A-body mopar(I have the A-body 8 3/4 on top of the mono-leaf spring with a shackle flip in the 88 440 truck),looks like a traction bar but replaces the shock plate and clamps to the leaf spring in the same spot caltracs does,just behind the front spring eye. it lifts the back of my truck about 4-5 inches and plants the tires on the launch. I dont mind the snickers about the traction bars on a mopar thing,it works for me,with out them it goes up in smoke and has some wheel hop with 12" rim and a 29x15x15 M/Ts that is not good. with the lift bars it hooks out the hole and no spin or hop from the alxe. i would run the ansen ground grabbers or ssm lift bars not the cheap autozone/lakewood slapper bars for chebbys run what ya brung
[Re: scratchnfotraction]
#1223302
05/01/12 09:48 AM
05/01/12 09:48 AM
Mr.Yuck
Brookeville, Md
run what ya brung
those SSM lift bars are great. ran them on an old 68 Dart. They do make the ride a tad rough... I was thinking of trying them on the Charger as they are a lot cheaper then Cal-Tracs
