Final Showdown: traction bars - YES or NO? #1223283
04/27/12 10:00 PM
04/27/12 10:00 PM
delivering your oil
nutso suave Offline OP
delivering your oil
here is the question...should you put slapper bars on a mopar? i was laughed out of the forum 5 years ago when i asked this question, but since then several drag racers have told me that traction bars work better than adjustable pinion snubbers. what is the consensus here?
if i was going to add a set, i'd use these ansen ground grabbers:
slapper bars: yay or nay?
single choice
Votes accepted starting: 04/27/12 08:42 PM
You must vote before you can view the results of this poll.
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223284
04/27/12 10:22 PM
04/27/12 10:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Well I added a set to my XHD springs and well...the 60 foot was worse, but I had some other issues as well so I'm not sure I want to blame it all on them yet. They get one more chance and they wil come off. Right at th etrack as a matter of fact.
Coming soon!!!!
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223285
04/27/12 10:46 PM
04/27/12 10:46 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Well I think the answer is "relative".
Mopar always claimed that their springs were biased side to side and the muscle cars had longer front segments to minimize wind-up. Fine - for the stock tires!
But as soon as you stuck some different rubber on the rear that changed things. Now you had the option of a s/s spring, an adjustable snubber or both.
Let's face it, a) the springs weren't cheap and b) the snubber was either "on" or "off", meaning to make it plant the tires it pretty much had to be touching the floor and that gave you a lousy ride if you left it there.
The slapper bars were a different animal, relatively inexpensive and they could be "tuned" such that they wouldn't do anything until you "got on it" and the springs started to wind up.
So my opinion is if they work for your Mopar, they belong on it.
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223286
04/27/12 10:49 PM
04/27/12 10:49 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Not no.......but HELL NO!
Springs, shocks, pinion angle, drive height, weight transfer, tire compound, etc, etc.
But not slappers.
And, to be honest, the only thing that pinion snubbers ever did for me was stop the rear U-joint from being twisted out when I had poor rear set-ups way back when.
Master, again and still
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223287
04/28/12 10:25 PM
04/28/12 10:25 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
If your springs a set up properly, the body will seperate from the axle, or rise, and snubber and/or slappers are rendered useless.
Slappers typically hit the leafs just aft of the main eye, right in the weakest part of the spring. If the are doing that, good chance your going to bend your main leaf as it trys to lever the car's body up. Think of it this way, would you use a floor jack in this spot? That's what slappers are doing.
Re: Final Showdown: traction bars - YES or NO? [Re: TC@HP2] #1223288
04/28/12 10:49 PM
04/28/12 10:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I get between 4 and 5 inches of lift out of my rear springs. The snubber does not contact the floor.
I certainly don't need slappers.
- Stu Harmon
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223289
04/29/12 09:00 AM
04/29/12 09:00 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
CalTrac's obviously work and they are slapper bars that were refined to a fully functioning level. The "poor man's 4-Link" as one could say. They basically reapply the wind-up forces into a downward motion for the axle.
And one of the reasons the old Direct Connection manuals pumped up the P-snubber and rejected the slapper bars was to sell their own product.
Re: Final Showdown: traction bars - YES or NO? [Re: TC@HP2] #1223290
04/29/12 12:14 PM
04/29/12 12:14 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
traction bars should be pushed forward up under the leaf spring mount, not under the spring itself.
Re: Final Showdown: traction bars - YES or NO? [Re: Dean_Kuzluzski] #1223291
04/29/12 12:48 PM
04/29/12 12:48 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
caltracs, the "hi-tech" slapper bar. they do what they are supposed to do. so does the pinion snubber, if your ride isnt jacked to the sky.
Re: Final Showdown: traction bars - YES or NO? [Re: Golden-Arm] #1223292
04/29/12 01:24 PM
04/29/12 01:24 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
All traction bars do is control any wheel hop issues you may have. Pinion snubbers do the same thing. They keep the pinion from walking up the ring gear.
Like this:
Traction bars stop it and snubbers stop it. One stops it from the center and one stops it from the outside. The reason traction bars are frowned on in the Mopar ranks is because Mopar sells a snubber. Reason two is that a lot of traction bars are built for Brand X and therefore extend beyond the front shackle. In fact a lot of traction bars are 21 inches or better but the front spring segment is 20 inches for A-Body and as long as 24 inches for the Barges. I believe Mopar Performance also sold clamps for the front spring segments to stiffen the front segment up. So yes. If you're getting wheel hop then traction bars can and will work. The only thing about traction bars is that some of "Those Guys" have been known to twist their housing on launch.
Re: Final Showdown: traction bars - YES or NO? [Re: Leadfoot] #1223293
04/29/12 03:06 PM
04/29/12 03:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Like this:
Your graphic is bassackwards in direction
Don't be the exception.
Re: Final Showdown: traction bars - YES or NO? [Re: Supercuda] #1223294
04/29/12 03:10 PM
04/29/12 03:10 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
I didn't really even notice that. I copied it off the internet without paying attention to the arrows. I just assumed they were made to advance to the next screen as part of a slide presentation or something like that. I wonder how many people now have their traction bars sticking out the back thanks to me.
Re: Final Showdown: traction bars - YES or NO? [Re: Supercuda] #1223295
04/29/12 03:23 PM
04/29/12 03:23 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
Like this:
You sure about that? It looks like the front of the car would be to the right of the graphic (we're looking at the right side of the car in the diagram), the rear leaf spring shackle is on the left side of the graphic, at the back of the car.. it looks like the tire is rotating clockwise, moving the car forwards... looks correct to me.
Re: Final Showdown: traction bars - YES or NO? [Re: cal_gecko] #1223296
04/29/12 03:28 PM
04/29/12 03:28 PM
ky.
K
kenworth_goose Offline
K
ky.
Like this:
Wrong! When you look at this picture, the pinion is going towards the ground, that is the opposite of what happens. When you accelerate the pinion will go in the opposite direction, or up.
Re: Final Showdown: traction bars - YES or NO? [Re: kenworth_goose] #1223297
04/29/12 03:31 PM
04/29/12 03:31 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
D'oh, good point.. they have the rotational twisting effect going in the wrong direction !
Re: Final Showdown: traction bars - YES or NO? [Re: cal_gecko] #1223298
04/29/12 03:45 PM
04/29/12 03:45 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Tire direction is OK, pinion deflection direction wrong, spring wrap/movement is opposite what is shown... other than most everything backwards it's a great diagram.
On a well set up leaf spring car, a pinion snubber is a band aid at best. Great for propping the door of the shop open for a breeze. Clamp the snot out of the front segments and the snubber isn't even needed.
Re: Final Showdown: traction bars - YES or NO? [Re: RobX4406] #1223299
04/29/12 04:30 PM
04/29/12 04:30 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Found this on the web and tweaked it a bit.....
Re: Final Showdown: traction bars - YES or NO? [Re: Reggie] #1223300
04/30/12 10:12 PM
04/30/12 10:12 PM
delivering your oil
delivering your oil
Thanks for the info...sounds like it is a bad idea.
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223301
05/01/12 09:36 AM
05/01/12 09:36 AM
scratchnfotraction Offline
I use a south side machine lift bar thats for an A-body mopar(I have the A-body 8 3/4 on top of the mono-leaf spring with a shackle flip in the 88 440 truck),looks like a traction bar but replaces the shock plate and clamps to the leaf spring in the same spot caltracs does,just behind the front spring eye.
it lifts the back of my truck about 4-5 inches and plants the tires on the launch.
I dont mind the snickers about the traction bars on a mopar thing,it works for me,with out them it goes up in smoke and has some wheel hop with 12" rim and a 29x15x15 M/Ts that is not good.
with the lift bars it hooks out the hole and no spin or hop from the alxe.
i would run the ansen ground grabbers or ssm lift bars not the cheap autozone/lakewood slapper bars for chebbys
run what ya brung
Re: Final Showdown: traction bars - YES or NO? [Re: scratchnfotraction] #1223302
05/01/12 09:48 AM
05/01/12 09:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
run what ya brung
those SSM lift bars are great. ran them on an old 68 Dart. They do make the ride a tad rough... I was thinking of trying them on the Charger as they are a lot cheaper then Cal-Tracs
