Fuel Pump Spitting #122259
09/17/08 04:06 PM
09/17/08 04:06 PM
Central Florida
moparhoover71 Offline OP
Central Florida
I have a 1985 ramcharger with a 318 and my fuel pump is spitting out of the top, it not any sort of connection point i.e. leading to the engine or fuel filter or anything its just coming out of this raised bar on top with two ends, one end is not spitting but the other is? the side thats not spitting is covered in grime, but I couldn't find a nut or screw or something that would be on the good side and not on the bad side to cause this? I've never had a fuel pump issue before so it's kind of aggrevating.
'75 Swinger - project underway Hold Fast
Re: Fuel Pump Spitting [Re: moparhoover71] #122260
09/17/08 05:10 PM
09/17/08 05:10 PM
Central Florida
Central Florida
need to drive her to school tomorrow, any input?
Re: Fuel Pump Spitting [Re: moparhoover71] #122261
09/17/08 05:25 PM
09/17/08 05:25 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Is this a mechanical pump on the engine? If so, it sounds like the rubber diaphram has failed and I'm afraid it will only get worse. If its electric its still probably going to have to be replaced if its not leaking for a fitting
Re: Fuel Pump Spitting [Re: moparhoover71] #122262
09/17/08 05:25 PM
09/17/08 05:25 PM
Sacramento, CA
K
Kirk_Ingram Offline
super street
Kirk_Ingram  Offline
super street
K
Sacramento, CA
Replace the pump.
Sounds like the diaphragm is ruptured. If so, it may be dumping fuel into the crank case also. Check your oil.
Death or Glory...it's just another story.
Re: Fuel Pump Spitting [Re: Kirk_Ingram] #122263
09/17/08 05:58 PM
09/17/08 05:58 PM
DO NOT DRIVE THE VEHICLE
REPEAT DO NOT DRIVE THE VEHICLE
"Spitting fuel" in any amount is dangerous enough, but if this is a mechanical pump, it will inject fuel into the crankcase
IN MY LIFE --and I'm and old fart-- I've seen two engines with leaking fuel pumps suffer crankcase explosions. One on a 57 Chev blew off the oil filler cap hard enough to dent the hood, and blew off a valve cover. Another, a ford, pretty much ruined the oil pan!!!!!
Re: Fuel Pump Spitting #122264
09/17/08 06:00 PM
09/17/08 06:00 PM
Central Florida
Central Florida
EXACTLY what I needed to hear, I wasn't sure if I could limp to school tomorrow or not, but now I know for sure. Does this mean a mandatory oil change or just check it for a smell of gas? Thanks.
Re: Fuel Pump Spitting [Re: moparhoover71] #122265
09/17/08 06:04 PM
09/17/08 06:04 PM
If this is a mechanical pump, there is no question in my mind: An oil AND filter change are a lot cheaper than a wiped out crank
Re: Fuel Pump Spitting #122266
09/17/08 06:08 PM
09/17/08 06:08 PM
Central Florida
Central Florida
Thanks again guys, I believe i have about an hour to go spend in the driveway now.
