Re: Fuel Pump Spitting
[Re: moparhoover71]
#122262
09/17/08 06:25 PM
09/17/08 06:25 PM
Posts: 616 Sacramento, CA
Kirk_Ingram
super street
super street
Sacramento, CA
Replace the pump. Sounds like the diaphragm is ruptured. If so, it may be dumping fuel into the crank case also. Check your oil.
Death or Glory...it's just another story.
[Re: Kirk_Ingram]
#122263
09/17/08 06:58 PM
09/17/08 06:58 PM
DO NOT DRIVE THE VEHICLE
REPEAT DO NOT DRIVE THE VEHICLE
"Spitting fuel" in any amount is dangerous enough, but if this is a mechanical pump, it will inject fuel into the crankcase
IN MY LIFE --and I'm and old fart-- I've seen two engines with leaking fuel pumps suffer crankcase explosions. One on a 57 Chev blew off the oil filler cap hard enough to dent the hood, and blew off a valve cover. Another, a ford, pretty much ruined the oil pan!!!!!
[Re: moparhoover71]
#122265
09/17/08 07:04 PM
09/17/08 07:04 PM
If this is a mechanical pump, there is no question in my mind: An oil AND filter change are a lot cheaper than a wiped out crank
#122266
09/17/08 07:08 PM
09/17/08 07:08 PM
Posts: 43 Central Florida
moparhoover71
Central Florida
Thanks again guys, I believe i have about an hour to go spend in the driveway now.
'75 Swinger - project underway
Hold Fast
