What style tube bender? #1220476
04/22/12 01:53 PM
04/22/12 01:53 PM
Auburn, Indiana
The Duster Offline OP
Auburn, Indiana
Which style tubing bender do you guys recommend for roll cage / chassis? Vertical or horizontal? I like how easy it looks to measure angle of bend using a digital angle gauge on the vertical style benders. Considering the JD2 model 32 and building my own hydraulic system for it.
I plan on bending a cage for my car, and little jobs for others. I can retire in 7 years and hope I can do this with other hot rod building as my retirement job.
Re: What style tube bender? [Re: The Duster] #1220477
04/22/12 03:53 PM
04/22/12 03:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is the one I've been using for about 15 years...
its a Pro Tools (use to be model 104) but now its a
model 105B
Re: What style tube bender? [Re: The Duster] #1220478
04/22/12 07:00 PM
04/22/12 07:00 PM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
The Hossfeld #2 bender has also been a favorite of chassis builders for years. It is similar to the one shown by Mr. Peabody. The conduit style benders will not give you the short radius bends that you need to properly buld a roll cage. I believe the Hossfelds are built in Minnesota. My brother and I built our own bender framework years ago and bought the Hossfeld dies.
Re: What style tube bender? [Re: reknapp52] #1220479
04/23/12 09:41 PM
04/23/12 09:41 PM
Auburn, Indiana
Auburn, Indiana
After the bender, notcher, and welder, what other tools do you guys use most for chassis / roll cage fab?
Re: What style tube bender? [Re: The Duster] #1220480
04/23/12 09:56 PM
04/23/12 09:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A couple more things you will need... a tubing inclinometer
for setting up the rotational degees, a oscillating
drum sander to fine tune the notches, a belt sander...
thats about it
Re: What style tube bender? [Re: The Duster] #1220481
04/23/12 10:34 PM
04/23/12 10:34 PM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
You'll need a decent band saw, and a machinist's protractor comes in handy. We have never used a tubing notcher, we make our cuts with a hole saw on a vertical mill. Used a drill press in the early days, but it's slow going, and we broke lots of teeth off the hole saws.
Re: What style tube bender? [Re: MR_P_BODY] #1220482
04/23/12 11:36 PM
04/23/12 11:36 PM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
What's a "tubing inclinometer" look like? My google search only turned up sensors and such.
Re: What style tube bender? [Re: Scott58] #1220483
04/23/12 11:41 PM
04/23/12 11:41 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I have a jd32 electric over hydro. Damn nice piece.
Re: What style tube bender? [Re: Scott58] #1220484
04/23/12 11:49 PM
04/23/12 11:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I go take a pic... but it slides over the tube then
you tighten down the thumb screw so you can pul the
tube out and turn the tube around and still be on the
same plan... or if you want 2 legs the same angle
like on the main hoop
Re: What style tube bender? [Re: The Duster] #1220485
04/24/12 04:46 AM
04/24/12 04:46 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
in my opinion, this would be the best setup...I love fliptops...they're accurate and easy to use...I used a Greenlee setup for pipe in all different configurations for well over 40 years as an Electrician...I can't afford this one, but its the way to go
http://www.pro-tools.com/product.aspx?zpid=342
but, this is what I have and is a good setup..uses an air over hydraulic ram from Harbor Freight for $90 and the conversion for $110...I think the bender is a JD3 with a 1 5/8" shoe or die as they call it...I may have paid close to $600 for it...I dont remember cause it was about 12 years ago..
it too is a good bender but why I like the fliptops is because its easier to pull the pipe out and they are one shot benders...
Re: What style tube bender? [Re: smokinwoody] #1220486
04/25/12 12:22 AM
04/25/12 12:22 AM
Auburn, Indiana
Auburn, Indiana
I was looking at Jerry Bickel's chassis school class on his website, and that appears to be the one they are using. More than I want to spend though.
Re: What style tube bender? [Re: The Duster] #1220487
04/25/12 02:12 AM
04/25/12 02:12 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
anyone ever seen anything like this in person?
http://www.youtube.com/embed/yigRgG_NIyU
