Page 4 of 4 1 2 3 4
Re: School me on overdrive transmissions for a RB [Re: 1_WILD_RT] #1219223
05/05/12 12:25 AM
05/05/12 12:25 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The important part is finding out how much modification is required on a 72 Imperial.
- Stu Harmon
Re: School me on overdrive transmissions for a RB [Re: feets] #1219224
05/05/12 12:31 AM
05/05/12 12:31 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
You should have no problem fitting this thing under that whale.. lotsa room
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: School me on overdrive transmissions for a RB [Re: feets] #1219225
05/05/12 12:33 AM
05/05/12 12:33 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not really, you've never impressed me as the kind of guy thats scared of a little modification... Off memory your Imperial may have a little more room to work with, fact is I seem to recall because it's full frame the torsion bar crossmember doesn't pass over the top of the transmission so there wouldn't be much of a problem...
Re: School me on overdrive transmissions for a RB [Re: 1_WILD_RT] #1219226
05/05/12 01:54 AM
05/05/12 01:54 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
True, but I'd like to avoid hacking the Imperial.
It's disturbing how little room there is around the engine and transmission in a car this size. Changing the plugs takes longer than it did in the hot rod with the turbos. The trans tunnel is pretty small too.
I've been looking at this thing from time to time trying to figure out how to stuff the turbos in there. There's lots of room for the turbos but getting the plumbing run without messing with all the other systems is a mess.
- Stu Harmon
Re: School me on overdrive transmissions for a RB [Re: DARTH V8Я] #1219227
05/07/12 09:50 AM
05/07/12 09:50 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I'm sure it would raise a few eyebrows if they got some installation inquiries about putting that in an Imp. Their first question for you would be how/where you got it.
A car-sized version of that would be pretty cool, but we'd have to turn to Audi (I think) to get one.
Re: School me on overdrive transmissions for a RB [Re: Fury Fan] #1219228
05/07/12 01:03 PM
05/07/12 01:03 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
A518 with either a JVX adapter or JW Ultrabell.
http://www.cuda-challenger.com/cc/index.php?topic=84774.0
Many folks have done it in an e-body w/o hacking the car. Slapstick shifter works too.
I plan on doing the same mod.
I'm just curious on converter...for non-lockup.
They say, that you should get stall speed that's less than what you cruise at 65mph.
With 4.10 gears, and with a .75OD (3.07) and 26" tall tires, that means running 2600RPM. Does that mean I have to get a 2500 stall 'verter? That seems kinda low if you got a hot street engine.
Re: School me on overdrive transmissions for a RB [Re: 2fast4yourBrain] #1219229
06/28/12 09:49 PM
06/28/12 09:49 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Someone mentioned earlier in this post that the 71-up Es don't need to have the crossmember modded but that the 70s do. Is that true? I never knew that there was a difference in the crossmember area between the years.
So, is there a difference that affects the install of a 518?
Master, again and still
Re: School me on overdrive transmissions for a RB [Re: DaveRS23] #1219230
09/14/13 12:27 PM
09/14/13 12:27 PM
Beeton Ontario. Canada
BigSugar Offline
BigSugar  Offline
Bump
Page 4 of 4 1 2 3 4
