How much HP to expect? SB
#1219096
04/20/12 02:49 PM
04/20/12 02:49 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
360 .030 over tq plate honed, moly rings hydraulic flat tappet 231@.050 .583 lift single pattern 2.02 mild port job 5 angle valve job R/T heads 270@.550M1 single plane 900 CFM CS T-quad 1 5/8 hooker headers 11.3 compression What kind of crank HP/TQ to expect and what kind of ET from a well set up #3200 race weight A-body?
Re: How much HP to expect? SB
[Re: HotRodDave]
#1219097
04/20/12 02:54 PM
04/20/12 02:54 PM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
I'm thinking it "could" come close to 500 HP, depends on a lot of factors but 480 should be easily within reach.
[Re: HotRodDave]
#1219100
04/20/12 03:50 PM
04/20/12 03:50 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
ET is going to depend on the chasis...converter, gearing and tires..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 540challenger]
#1219103
04/20/12 05:05 PM
04/20/12 05:05 PM
Posts: 382 Roseville MN
72swgnr
Roseville MN
Do you plan on putting it on the dyno? If so I'm interested in the results. I'm using a set of Brian@IMM RHS heads, m1 single plane, Solid cam with around the same lift as you in a stock stroke 360. I just have to get around to getting the correct thickness head gaskets and a few other little things and then it can be put together.
[Re: Streetwize]
#1219106
04/20/12 06:05 PM
04/20/12 06:05 PM
HotRodDave
Kalispell Mt.
I already have the cam and headers so they will be sticking around. I have all the stuff for the short block and the heads. The only thing I do not have is an intake, bearings, and a few gaskets.
I will be driving it on the street also so I probably would not make the cam any bigger if I could and If I had a choice about the headers I would probably use 340 manifolds instead. The only other exhaust option I have is 273 manifolds.
[Re: ademon]
#1219109
04/21/12 12:13 AM
04/21/12 12:13 AM
HotRodDave
Kalispell Mt.
Engle cam specifically for mopar lifters with 1.7 rockers. I originally had it ground for a bigger engine with a tad less compression, then I had to sell my stroker short block. I hope it is not too lumpy for this combo
[Re: HotRodDave]
#1219111
04/21/12 12:42 AM
04/21/12 12:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Whats the LSA on that cam
