XV Motorsports box tubing lower radiator support #1218255
04/18/12 02:36 PM
04/18/12 02:36 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Has anyone else used the boxed tubing XV Motorsports lower radiator support? What is everyone using for a replacement radiator? My Factory 26" Radiator no longer will fit. The bottom of the rad hits the upper portion of the tubing not allowing it to sit down all the way.I welded it in with their supplied drop pieces & it is obviously not enough of a drop but anymore & it would hang way to low looking from the front.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: XV Motorsports box tubing lower radiator support [Re: 6PKRTSE] #1218256
05/11/12 04:09 PM
05/11/12 04:09 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
All of the big rim & tire Pro Touring combo's running around & no-one has tried the XV rad support?
Re: XV Motorsports box tubing lower radiator support [Re: 6PKRTSE] #1218257
05/11/12 04:21 PM
05/11/12 04:21 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I installed it in my 70GTX withOUT the extensions on the bottom. I have installed the radiator from the same 07 Charger I got the 5.7 hemi from however, so I cannot respond to your particular issue. I can say the Charger radiator and attached A/C Condenser fit just fine. All I had to do was weld two "Flanges" to the bottom of the rad stiffener for bottom support/rest for the radiator I used.
Driving modern convenience in classic beauty
Re: XV Motorsports box tubing lower radiator support [Re: Darius] #1218258
05/11/12 08:15 PM
05/11/12 08:15 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
On my 68 A-body, I have a similar design US Cartool lower radiator brace set back from the radiator enough to clear it. I also used the spacers to lower it.
Re: XV Motorsports box tubing lower radiator support [Re: Darius] #1218259
05/11/12 08:16 PM
05/11/12 08:16 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
good luck buying one - they have been trying to sell thier blemished ones for over a year now - and every time I call the answer is still the same - "maybe next month". I decided to make my own outta 1.75" .120 wall DOM tubing - worked great.
Re: XV Motorsports box tubing lower radiator support [Re: 6PKRTSE] #1218260
05/12/12 11:51 PM
05/12/12 11:51 PM
blewbyu Online content
blewbyu  Online Content
I used an aftermarket radiatory for my car, here is the cross member in my car. It will depend how far forward you mount it on the frame rails i'm guessing if you are going to use the factory radiator.
Re: XV Motorsports box tubing lower radiator support [Re: blewbyu] #1218261
05/17/12 05:02 PM
05/17/12 05:02 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
I mounted it in the same factory location not thinking about moving it forward any. Don't know if I could have gone much further forward. I am probably going to be using an aftermarker light weight rad of some sort anyway. I was just cleaning up the garage a little & had a factory laying around & decided to set it in my engine bay to keep it out of the way & that is when I noticed it no longer wil fit. Anyone no of a rad that is not so tall but is the same 26" width?
