XV Motorsports box tubing lower radiator support
#1218255
04/18/12 02:36 PM
04/18/12 02:36 PM
Posts: 4,561 Motor City
6PKRTSE
Motor City
Has anyone else used the boxed tubing XV Motorsports lower radiator support? What is everyone using for a replacement radiator? My Factory 26" Radiator no longer will fit. The bottom of the rad hits the upper portion of the tubing not allowing it to sit down all the way.I welded it in with their supplied drop pieces & it is obviously not enough of a drop but anymore & it would hang way to low looking from the front.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: XV Motorsports box tubing lower radiator support
[Re: 6PKRTSE]
#1218256
05/11/12 04:09 PM
05/11/12 04:09 PM
6PKRTSE
Motor City
All of the big rim & tire Pro Touring combo's running around & no-one has tried the XV rad support?
[Re: 6PKRTSE]
#1218257
05/11/12 04:21 PM
05/11/12 04:21 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I installed it in my 70GTX withOUT the extensions on the bottom. I have installed the radiator from the same 07 Charger I got the 5.7 hemi from however, so I cannot respond to your particular issue. I can say the Charger radiator and attached A/C Condenser fit just fine. All I had to do was weld two "Flanges" to the bottom of the rad stiffener for bottom support/rest for the radiator I used.
Driving modern convenience in classic beauty
[Re: Darius]
#1218258
05/11/12 08:15 PM
05/11/12 08:15 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
On my 68 A-body, I have a similar design US Cartool lower radiator brace set back from the radiator enough to clear it. I also used the spacers to lower it.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: blewbyu]
#1218261
05/17/12 05:02 PM
05/17/12 05:02 PM
6PKRTSE
Motor City
I mounted it in the same factory location not thinking about moving it forward any. Don't know if I could have gone much further forward. I am probably going to be using an aftermarker light weight rad of some sort anyway. I was just cleaning up the garage a little & had a factory laying around & decided to set it in my engine bay to keep it out of the way & that is when I noticed it no longer wil fit. Anyone no of a rad that is not so tall but is the same 26" width?
