Re: Thought I had it fixed ?
[Re: rickraw]
#1217794
04/17/12 05:54 PM
04/17/12 05:54 PM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
fwiw, dont use the metal seats for the street, rubber are more forgiving and will seal better gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: topside]
#1217798
04/17/12 06:47 PM
04/17/12 06:47 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
hey Ron , i tried the steel N/S combo a little while back.Do not use them unless you drop your pressure way down - like to 3 psi.otherwise they will flood regularly.i went back to stock viton no more flooding.I think they are are designed for alchohol - high volume low pressure
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Quicksilver440]
#1217800
04/18/12 01:13 PM
04/18/12 01:13 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I'll bet you have a litle speck of junk holding the needle and seat open.....even a tiny speck can do it.
Well I thought that at first but it only seems to happen after I drive it and get it hot. And it has done it about 4 times. I put a new fuel pump and regulator on it and it did it again so thats why I thought the pump gas might be messing with the rubber needle and seats. Ron
[Re: 383man]
#1217802
04/18/12 02:25 PM
04/18/12 02:25 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Where is your filter Ron? I have had similar problems out here with non Ethanol pump swill in my Dominators with .120 viton needles and seats I use a 80 micron filter between the tank and the pump and a 10 micron filter between the pump and the regulator. I did end up dropping the pressure to 5.5 lbs. after replacing the .110 viton needles per Monte Smith suggestions on here several years ago, the larger needles have more area needing more pressure to close them and they flow more fuel at the lower pressures Why not try that
[Re: 383man]
#1217803
04/18/12 02:44 PM
04/18/12 02:44 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Do you have a deadhead fuel system? Your problem sounds familiar. I put a return style system on mine and it fixed it. The pump gas available now definitely seems more susceptible to vapor lock.
[Re: an8sec70cuda]
#1217804
04/18/12 03:37 PM
04/18/12 03:37 PM
Posts: 17,875 S.E. Michigan
ZIPPY
S.E. Michigan
Maybe the car is trying to tell you something: Maybe it doesn't like the ex. kidding Mine was acting up sort of the same a few weeks ago, first fire up of the season, ran terrible, same kind of symptoms....found a tiny piece of translucent plastic stuck in the needle and seat. Blew it out, and it was perfect after that. This might sound silly but make sure the oil hasn't got contaminated with all that fuel.
Rich H.
Esse Quam Videri
