E-Body Wiper Gear #121726
09/16/08 03:29 PM
09/16/08 03:29 PM
MoreParts Offline OP
Hello Folks, anyone know a source for the big wiper gear for the variable speed motor? Mine needs replacing in my '70 Challenger.
Also, I can't get it to park correctly. I noticed a piece of plastic is broken from that big gear, so I'm hoping that's at least part of my problem. The point on the front round plate appears intact and functional. I also tried another switch and that didn't help either, although I can't be certain the other switch was 100percent working, but it did carry through with the parking problem. The wipers will just stop wherever the power is turned off or ignition is stopped.
Re: E-Body Wiper Gear [Re: MoreParts] #121727
09/16/08 04:02 PM
09/16/08 04:02 PM
30 Rock
JS29 Offline
JS29  Offline
30 Rock
You need to contact Julesthewperman a member here. He is the Mr. KnowItAll when it comes to wipers.
http://www.julesdaddio.com/index.html
Re: E-Body Wiper Gear [Re: MoreParts] #121728
09/16/08 04:10 PM
09/16/08 04:10 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Here is the correct gear for your application. Note that not all gears are the same even though many sellers
state 67-75. Not true.
http://cgi.ebay.com/ebaymotors/NOS-MOPAR...sspagenameZWD1V
Concerning your parking problems.
1) Could be a bad ground on your dash switch. Since your motor works it is not a bad ground on the motor.
2) Bad dash switch. The circuit breaker inside the switch maybe be burnt or defective.
3) Front switch plate on the motor itself is not making a good contact. Make sure the brass tang inside has a good
pressure and contact is clean.Make sure outside wires are soldered properly to their respective posts.
4) Blue wire connection on firewall or plug is not good. Check wires for breaks or oxidation.
Please do not ask me to sell you a gear as I need them to earn a living restoring motors.
Jules
Re: E-Body Wiper Gear [Re: JulesdaWiperman] #121729
09/16/08 06:19 PM
09/16/08 06:19 PM
Thank you Jules! I won't ask, but I can wish.
I know they have a much cheaper kit for the 71+. The gear looks very similar. Will that work if I only use that part from the kit and the other parts from my existing motor?
Re: E-Body Wiper Gear [Re: MoreParts] #121730
09/16/08 06:37 PM
09/16/08 06:37 PM
super gas
super gas
Similar is the correct word.
If you could email me a picture of your internals, I can better guide you in your search.
Sometimes motors have been tampered with and internal components might have been changed so
I need to see what you have going right now.
My email is gdaddio@videotron.ca
In the meantime, a 71 and up gear may work if you find an early 71 model. Later models
had metal plates installed.
Jules
Re: E-Body Wiper Gear [Re: JulesdaWiperman] #121731
09/16/08 07:30 PM
09/16/08 07:30 PM
Thank you, sir! You've got mail.
Re: E-Body Wiper Gear [Re: MoreParts] #121732
09/16/08 08:26 PM
09/16/08 08:26 PM
One other question for you. How do you align the round top plate when you put it back on? I've noticed there is a little tab that sticks out of it, but it looks like it could go in a few different positions.
Re: E-Body Wiper Gear [Re: MoreParts] #121733
09/16/08 08:37 PM
09/16/08 08:37 PM
super gas
super gas
You've got mail.
Re: E-Body Wiper Gear [Re: JulesdaWiperman] #121734
09/16/08 09:14 PM
09/16/08 09:14 PM
Back at ya!
Re: E-Body Wiper Gear [Re: MoreParts] #121735
09/16/08 10:21 PM
09/16/08 10:21 PM
super gas
super gas
Your move.
Jules
