Re: E-Body Wiper Gear
[Re: MoreParts]
#121728
09/16/08 04:10 PM
09/16/08 04:10 PM
Posts: 2,984 Montreal,Quebec,Canada
JulesdaWiperman
super gas
super gas
Here is the correct gear for your application. Note that not all gears are the same even though many sellers state 67-75. Not true. http://cgi.ebay.com/ebaymotors/NOS-MOPAR...sspagenameZWD1VConcerning your parking problems. 1) Could be a bad ground on your dash switch. Since your motor works it is not a bad ground on the motor. 2) Bad dash switch. The circuit breaker inside the switch maybe be burnt or defective. 3) Front switch plate on the motor itself is not making a good contact. Make sure the brass tang inside has a good pressure and contact is clean.Make sure outside wires are soldered properly to their respective posts. 4) Blue wire connection on firewall or plug is not good. Check wires for breaks or oxidation. Please do not ask me to sell you a gear as I need them to earn a living restoring motors. Thanks Jules
[Re: MoreParts]
#121730
09/16/08 06:37 PM
09/16/08 06:37 PM
JulesdaWiperman
super gas
super gas
Similar is the correct word. If you could email me a picture of your internals, I can better guide you in your search. Sometimes motors have been tampered with and internal components might have been changed so I need to see what you have going right now. My email is gdaddio@videotron.caIn the meantime, a 71 and up gear may work if you find an early 71 model. Later models had metal plates installed. Jules
[Re: JulesdaWiperman]
#121734
09/16/08 09:14 PM
09/16/08 09:14 PM
MoreParts
