What size of bumpers under the upper control arms? #1215046
04/12/12 10:53 PM
04/12/12 10:53 PM
Nanaimo, B.C.
GwaiiEagle Offline OP
Mannix
Mannix
Nanaimo, B.C.
I never knew it could make a difference.
Does it?
Re: What size of bumpers under the upper control arms? [Re: GwaiiEagle] #1215047
04/13/12 12:31 AM
04/13/12 12:31 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
A taller upper bump stop will limit front suspension travel or "rise" of the front end...That will limit weight transfer. That being said, where can you buy taller than stock bumpers? i've got stock ones on my cars, but could use taller ones.
Re: What size of bumpers under the upper control arms? [Re: 340_Dart] #1215048
04/13/12 12:54 AM
04/13/12 12:54 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
With a little modification, the bumpers made for traction bars will work (slapper bars). You can also fabricate some spacers that will work.
Brian Dunnigan
Re: What size of bumpers under the upper control arms? [Re: '72CudaRacer] #1215049
04/13/12 02:46 AM
04/13/12 02:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would think you could unbolt the front ones and put a few washers under them to space them up some. Ron
Re: What size of bumpers under the upper control arms? [Re: 383man] #1215050
04/13/12 06:22 AM
04/13/12 06:22 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have 3/8 tall on mine I need all the travel I can get.
Re: What size of bumpers under the upper control arms? [Re: GwaiiEagle] #1215051
04/13/12 12:01 PM
04/13/12 12:01 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Cut 'em down for more front end travel, shim 'em or install taller ones for less travel.
Re: What size of bumpers under the upper control arms? [Re: Sixpak] #1215052
04/13/12 06:38 PM
04/13/12 06:38 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I welded in a nut and used a bolt to adjust front end travel. Very important on a drag car. I then put traction bar snubber and as many washers as possible on the lower control arm to answer another post about weak drag race torsion bars.
Leon
Re: What size of bumpers under the upper control arms? [Re: Leon441] #1215053
04/13/12 08:18 PM
04/13/12 08:18 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
The bottom is easy to see, but the top has one hole capped off. There is a bolt holding that cap on.
The the stop is farther in.
Re: What size of bumpers under the upper control arms? [Re: '72CudaRacer] #1215054
04/13/12 08:51 PM
04/13/12 08:51 PM
NC
440Jim Offline
440Jim  Offline
NC
Brian Dunnigan
That is what I have on my 1969 Dart. I limit travel to avoid excess wheel stand. I bought some nice traction bar bumpers and cut them to the length I wanted. Then on each track day, I put between zero and 0.437" of spacers under the bumper to set the amount of front end travel and weight transfer I need for the conditions.
A lower torque/horsepower car will want all the weight transfer they can get (short bumper), but a higher power car doesn't want to be on the bumper.
Re: What size of bumpers under the upper control arms? [Re: GwaiiEagle] #1215055
04/14/12 06:08 PM
04/14/12 06:08 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Energy Suspension has bump stops which can be cut to size:
http://www.amazon.com/Energy-Suspension-9-9101R-Performance-Polyurethane/dp/B005BDBE6K
They work well if you're looking for something taller than stock. They also sell shorter bump stops too.
Re: What size of bumpers under the upper control arms? [Re: Leon441] #1215056
04/14/12 09:11 PM
04/14/12 09:11 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Leon
So you would let your car ride on the bump stops?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: What size of bumpers under the upper control arms? [Re: 1967dartgt] #1215057
04/15/12 12:07 PM
04/15/12 12:07 PM
Sweden
Tobbe Offline
Tobbe  Offline
Sweden
