Problems with Comp Pro Magnum Rockers? #1214719
04/12/12 11:04 AM
04/12/12 11:04 AM
Mooresville, NC
A70Runner Offline OP
Mooresville, NC
I finally got my 496 onto the dyno. Break in went great! sounded good no leaks(other than junk valve covers) all ok...Go to do first pull on engine. Its making good power for a first pull and all of a sudden we hear a noise and power dropped off. Pulled the valve covers off and found 3 rockers seized to the shaft. Also bent three valves. Great....
I am now hearing that Comp changed the design of these rockers? I bought these in 2006. Is there a better rocker to use? The car has a solid roller in it. Going to be a street/strip car.
Thanks in Advance, I'm going to call comp and see what they say...
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: Problems with Comp Pro Magnum Rockers? [Re: A70Runner] #1214720
04/12/12 11:08 AM
04/12/12 11:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What spring pressures are you running ?
Re: Problems with Comp Pro Magnum Rockers? [Re: JohnRR] #1214721
04/12/12 11:16 AM
04/12/12 11:16 AM
Mooresville, NC
Mooresville, NC
275 seat 650 open
Re: Problems with Comp Pro Magnum Rockers? [Re: A70Runner] #1214722
04/12/12 11:22 AM
04/12/12 11:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Those must have been snug on the shaft to seize on
the first pull... TD rockers are much better BUT they
do cost more.... sorry you broke it
Re: Problems with Comp Pro Magnum Rockers? [Re: A70Runner] #1214723
04/12/12 11:26 AM
04/12/12 11:26 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
The new ones ( unsure when they changed ) are bushed.
Re: Problems with Comp Pro Magnum Rockers? [Re: A70Runner] #1214724
04/12/12 11:37 AM
04/12/12 11:37 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm guessing you made super sure that they were all lined up nicely w/ the tops of the valves?
Coming soon!!!!
Re: Problems with Comp Pro Magnum Rockers? [Re: A70Runner] #1214725
04/12/12 11:42 AM
04/12/12 11:42 AM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
I did that twice on my car with the same rockers, switched to harland sharps and haven't had an issue since...
Curtis
Taking over the World one win light at a time.
Re: Problems with Comp Pro Magnum Rockers? [Re: A70Runner] #1214726
04/12/12 11:45 AM
04/12/12 11:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
275 seat 650 open
That MAY be your problem, I think those ROCKERS are only good for 500 open.
Sharps or T+D's ... $$$$
edit ... Did you make and mods to your oiling to the top end that may be restricting oil ?
Shafts on the right way and are they banana groove ?
Re: Problems with Comp Pro Magnum Rockers? [Re: JohnRR] #1214727
04/12/12 11:54 AM
04/12/12 11:54 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
275 seat 650 open
There is your problem, I think those ROCKERS are only good for 500 open.
Fixed it for ya John
Re: Problems with Comp Pro Magnum Rockers? [Re: Moparnut426] #1214728
04/12/12 12:05 PM
04/12/12 12:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thanks , I have roller lifters on the brain
Re: Problems with Comp Pro Magnum Rockers? [Re: JohnRR] #1214729
04/12/12 12:09 PM
04/12/12 12:09 PM
Moparnut426 Offline
Moparnut426  Offline
FWIW, I think these rockers with the bushing are far better than the ones that failed in the this thread. Im sure the open PSI is able to be raised a bit.
Re: Problems with Comp Pro Magnum Rockers? [Re: JohnRR] #1214730
04/12/12 12:09 PM
04/12/12 12:09 PM
an8sec70cuda Offline
275 seat 650 open
Harland Sharps on my solid roller 440 w/ Indy heads...very happy w/ them. They were new in 1989, lol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Problems with Comp Pro Magnum Rockers? [Re: an8sec70cuda] #1214731
04/14/12 05:55 AM
04/14/12 05:55 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
AFAIK the non-bushed earlier Comp Magnum rockers must be run on banana grooved iron shafts.
Re: Problems with Comp Pro Magnum Rockers? [Re: afxcoronet] #1214732
04/14/12 10:02 AM
04/14/12 10:02 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Curtis
X2......been there, done that.......
If you can't handle the truth, you're living a lie.......
Re: Problems with Comp Pro Magnum Rockers? [Re: A70Runner] #1214733
04/14/12 10:40 AM
04/14/12 10:40 AM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
To determine root cause, other things need to be looked at like how the rockers are being oiled, side clearence.... That said, you were probably beyond the intended limit for the un-bushed version. At one time, I believe that CC qualified the unbushed rocker at 400# open.
Re: Problems with Comp Pro Magnum Rockers? [Re: A70Runner] #1214734
04/14/12 06:36 PM
04/14/12 06:36 PM
Indianapolis
Roadrunner451 Offline
Indianapolis
I have used those same rockers (the unbushed comps) at 580 open seat pressure with zero problems. It's a solid roller .648 lift and 262@.050. I drive the heck out of it, and beat on it at the strip as well. The shafts are just whatever came with the rockers. I have never checked the side clearance, but there is not very much at all since I use the Hughes shaft hold downs. If I remember right, I had to mill a little off the sides of thos hold downs to get them to work.
Re: Problems with Comp Pro Magnum Rockers? [Re: Roadrunner451] #1214735
04/15/12 10:30 AM
04/15/12 10:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have used those same rockers (the unbushed comps) at 580 open seat pressure with zero problems. It's a solid roller .648 lift and [Email]262@.050.[/Email] I drive the heck out of it, and beat on it at the strip as well. The shafts are just whatever came with the rockers. I have never checked the side clearance, but there is not very much at all since I use the Hughes shaft hold downs. If I remember right, I had to mill a little off the sides of thos hold downs to get them to work.
For every 5 people that have a problem there will be one that doesn't no matter what the item. Glad they are working well for you. Did you modify the oiling to them, maybe go to full time ?
A70 this guy brings up a good point , what hold downs were you using and was it held down with bolts or studs ? I was talking to Dan/Performance Only about this yesterday ...
Re: Problems with Comp Pro Magnum Rockers? [Re: BSB67] #1214736
04/15/12 01:16 PM
04/15/12 01:16 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Agree. Unbushed PMs at 650# open, it was just a matter of time.
I run them with 350# open and RAS hold downs.
Re: Problems with Comp Pro Magnum Rockers? [Re: 64Post] #1214737
04/16/12 09:51 AM
04/16/12 09:51 AM
Mooresville, NC
Mooresville, NC
Side clearance was good. I was running the comp hold downs with arp studs. I am just going with I should not have been running the unbushed ones.
Anyway I think I am going to switch to the Harlond Sharps. On the summit site it says you may have to restrict the oil flow to keep the oil pressure up. Did anyone have to do this? Thanks!
Re: Problems with Comp Pro Magnum Rockers? [Re: A70Runner] #1214738
04/16/12 12:02 PM
04/16/12 12:02 PM
Moparnut426 Offline
Moparnut426  Offline
Well I didnt on my small block, but I was VERY specific on keeping the side clearance set to the spec. That was oil dosnt bleed between the rockers.
May be different on big blocks though.
Kasey
