Problems with Comp Pro Magnum Rockers?
#1214719
04/12/12 11:04 AM
04/12/12 11:04 AM
Posts: 971 Mooresville, NC
A70Runner
Mooresville, NC
I finally got my 496 onto the dyno. Break in went great! sounded good no leaks(other than junk valve covers) all ok...Go to do first pull on engine. Its making good power for a first pull and all of a sudden we hear a noise and power dropped off. Pulled the valve covers off and found 3 rockers seized to the shaft. Also bent three valves. Great.... I am now hearing that Comp changed the design of these rockers? I bought these in 2006. Is there a better rocker to use? The car has a solid roller in it. Going to be a street/strip car. Thanks in Advance, I'm going to call comp and see what they say...
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: Problems with Comp Pro Magnum Rockers?
[Re: A70Runner]
#1214722
04/12/12 11:22 AM
04/12/12 11:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Those must have been snug on the shaft to seize on the first pull... TD rockers are much better BUT they do cost more.... sorry you broke it
[Re: A70Runner]
#1214725
04/12/12 11:42 AM
04/12/12 11:42 AM
Posts: 1,151 Las Vegas
afxcoronet
Las Vegas
I did that twice on my car with the same rockers, switched to harland sharps and haven't had an issue since... Curtis
Taking over the World one win light at a time.
[Re: JohnRR]
#1214727
04/12/12 11:54 AM
04/12/12 11:54 AM
Posts: 12,008 Finally a HUSKER again
Moparnut426
275 seat 650 open
There is your problem, I think those ROCKERS are only good for 500 open.
Sharps or T+D's ... $$$$
Fixed it for ya John
[Re: JohnRR]
#1214730
04/12/12 12:09 PM
04/12/12 12:09 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
275 seat 650 open
Harland Sharps on my solid roller 440 w/ Indy heads...very happy w/ them. They were new in 1989, lol.
[Re: A70Runner]
#1214734
04/14/12 06:36 PM
04/14/12 06:36 PM
Posts: 62 Indianapolis
Roadrunner451
Indianapolis
I have used those same rockers (the unbushed comps) at 580 open seat pressure with zero problems. It's a solid roller .648 lift and 262@.050. I drive the heck out of it, and beat on it at the strip as well. The shafts are just whatever came with the rockers. I have never checked the side clearance, but there is not very much at all since I use the Hughes shaft hold downs. If I remember right, I had to mill a little off the sides of thos hold downs to get them to work.
[Re: Roadrunner451]
#1214735
04/15/12 10:30 AM
04/15/12 10:30 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I have used those same rockers (the unbushed comps) at 580 open seat pressure with zero problems. It's a solid roller .648 lift and [Email]262@.050.[/Email] I drive the heck out of it, and beat on it at the strip as well. The shafts are just whatever came with the rockers. I have never checked the side clearance, but there is not very much at all since I use the Hughes shaft hold downs. If I remember right, I had to mill a little off the sides of thos hold downs to get them to work.
For every 5 people that have a problem there will be one that doesn't no matter what the item. Glad they are working well for you. Did you modify the oiling to them, maybe go to full time ?
A70 this guy brings up a good point , what hold downs were you using and was it held down with bolts or studs ? I was talking to Dan/Performance Only about this yesterday ...
[Re: 64Post]
#1214737
04/16/12 09:51 AM
04/16/12 09:51 AM
A70Runner
Mooresville, NC
Side clearance was good. I was running the comp hold downs with arp studs. I am just going with I should not have been running the unbushed ones.
Anyway I think I am going to switch to the Harlond Sharps. On the summit site it says you may have to restrict the oil flow to keep the oil pressure up. Did anyone have to do this? Thanks!
