Re: What Would Be The Ultimate Low Deck Engine Build?
[Re: MRMOPAR622]
#1214174
04/21/12 07:58 PM
04/21/12 07:58 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Thanks Twin Turbo Mower, I do not want the pistons coming out the bottom of the bore far enough to cause a problem either. All of this is some very valuable information.Thanks again! PS I am going to have to really do my home-work to stay on top of this build! ![](/ubbthreads/images/graemlins/thumbs.gif)
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: old yeller]
#1214177
04/22/12 04:06 AM
04/22/12 04:06 AM
Posts: 6,150 Melbourne , Australia
LA360
Run titanium intakes valves, I ordered Victory intakes for my friend's B1 engine. They were really nice. I ordered him Isky Red Zone EZX roll lifters also, we will see how they go.
Alan Jones
[Re: MRMOPAR622]
#1214179
04/22/12 07:29 AM
04/22/12 07:29 AM
Posts: 42 Sweden
ppmracing
Sweden
You are NOT loosing any HP on a 4.375 stroke compair to a 4.500,,, you got the same mabey moore but in a different rpm range. K1 4,375 stroke with Chevy BB rod journal, the you have allot off rods to pick from. 4,500 stroke get you to short rods,,,,
[Re: Twin Turbo Mower]
#1214182
04/22/12 01:14 PM
04/22/12 01:14 PM
MRMOPAR622
Sweet Home Alabama
Yes my block came from Indy stroke clearance. I went out and miked the pin boss on the CP they were .180. I guess my Caliper's are both in my box at work. So I had to measure the over all height of piston with the tape. It measured 2 7/16" so maybe close to 2.625. I will go over to the shop and bring one of my caliper's back to the shop beside the house where it belongs and get a more accurate measurement. But if I change the stroke will have to change the pistons,I have been doing this for 20+ years and never worried about anything other than the compression height. I know this is a dumb question,but does it matter how long or short the piston skirt is? If it doesn't a shorter piston skirt might be the answer? Thanks again everyone for all the great help! ![](/ubbthreads/images/graemlins/bow.gif)
[Re: MRMOPAR]
#1214183
04/22/12 01:19 PM
04/22/12 01:19 PM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
Currently my INDY Maxx has a Crower 4.15 crank with 6.570 BME rods and Wiseco pistons (this was an INDY combo at one time). Bob weight was 2144 gms.
I'm switching to a 4.15 K1 crank with K1 6.535 rods and an off the shelf ROSS piston. I had Brian at IMM(OU812) cam grind the counterweights for piston clearance. The bob weight with this combo comes in at 2163 gms, slightly more the BME AL rod combo.
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: MRMOPAR622]
#1214184
04/22/12 06:06 PM
04/22/12 06:06 PM
Posts: 1,056 Mt.Vernon IL
Twin Turbo Mower
Mt.Vernon IL
The piston skirt keeps the piston from rocking. Thats why the piston sticking to far out of the bottom of the bore it rocks more no support. Here is a pic of my old vs new pistons. One is shorter compression height but the skirt is the same length.
#1214185
04/22/12 07:59 PM
04/22/12 07:59 PM
MRMOPAR622
Sweet Home Alabama
Thanks again Twin Turbo Mower, I was hoping maybe getting the piston skirts as short as possible would minimized the amount that comes out of the bottom of the bore. I saw some real short pistons used in a Pro-Mod 760 or 780 cu in chevy engine,but I guess even in the bore the piston can still rock.
MRMOPAR at present my block does not oil through the push rods,but it can be converted over to oil through them. Just trying to decide if it is something I need to do,its not cheap time you finish with everything that is needed.
[Re: old yeller]
#1214186
04/22/12 10:00 PM
04/22/12 10:00 PM
Posts: 99 USA
BB Dart 69
USA
572ci low deck here.
There you go. One of the fastest cars on here!
