A-body driveshaft interchange #1213939
04/10/12 11:52 PM
04/10/12 11:52 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Are small and big block A-body driveshafts interchangeable? I am trying to find out if I can use a driveshaft from a 70 340 Dart on a 69 Dart with a big block transplanted into it.
Re: A-body driveshaft interchange [Re: 1970RT] #1213940
04/11/12 12:35 AM
04/11/12 12:35 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Short answer is yes, IF you are putting in a BB/727 in place of a SB/727.
If it's a 4 speed application, no prob either as long as the same trans and driveshaft will be used in the car again.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: A-body driveshaft interchange [Re: Sixgun] #1213941
04/11/12 11:03 AM
04/11/12 11:03 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
The car is currently a slant six automatic. I will be transplanting a big block and 727 using a small block k-frame. I have the 340 driveshaft from a prior project and just wanted to know if I would be able to use it.
Re: A-body driveshaft interchange [Re: 1970RT] #1213942
04/11/12 11:13 AM
04/11/12 11:13 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Is the 340 driveshaft for a 4 speed or an auto ?
ASSuMEing its for an auto and and 8 3/4 yes ... ASSuMEing it for the same body platform, Dodge and Plymouth have different wheelbase and thus different driveshafts , also the duster/demon dart sport had a specific driveshaft length , not sure what they are the same as.
Re: A-body driveshaft interchange [Re: JohnRR] #1213943
04/11/12 11:22 AM
04/11/12 11:22 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I don't recall what transmission the guy I bought it from said was in the car it came from. I will take a measurement of it today and post it later.
Re: A-body driveshaft interchange [Re: 1970RT] #1213944
04/11/12 05:28 PM
04/11/12 05:28 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
The driveshaft I have measures 48" center to center on the u-joints.
Re: A-body driveshaft interchange [Re: 1970RT] #1213945
04/11/12 06:41 PM
04/11/12 06:41 PM
JohnRR Offline
JohnRR  Offline
What car are you putting it in ?
