68 Coronet R/T Numbers matching or not?
#1213560
04/10/12 01:33 PM
04/10/12 01:33 PM
Posts: 216 united kingdom
Simonic
united kingdom
On a 68 Coronet should the number stamped on the id pad next to the starter be the same as the vin tag under the windshield please? Cheers
Simon
Keeping the Bee Buzzin'
Re: 68 Coronet R/T Numbers matching or not?
[Re: LimeliteAero]
#1213562
04/10/12 02:02 PM
04/10/12 02:02 PM
Simonic
united kingdom
Hi, Thank you for taking the time to reply to me. We are trying to find out if this car is indeed 'matching numbers'. The number i got from the pad next to the starter begins with 'PT440' and the block shows a casting date of 21/4/67. If not all 68 motors carry the VIN number is there any way to absolutly confirm or deny the relationship between the engine and the car? I will check the number up near the oil pressure sender asap
Thank you
Simon
[Re: Simonic]
#1213564
04/10/12 02:23 PM
04/10/12 02:23 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
Thank you
Simon
The PT number is the assembly info , are you sure on that date or is it 4/21/67 ? I know europeans tag the date differently , day then month vs. how the block is annotated month , day.
The VIN as said is on the bellhousing flange near the oil senders on the drivers side of the block , if an auto trans it will be stamped on the trans flange right above the engine , 4 speed is stamped down on the right side on a machined pad along with assembly Info.
If there is no VIN the only thing you can do is go by date coding and there is a gray area going by this.
[Re: JohnRR]
#1213565
04/11/12 09:23 AM
04/11/12 09:23 AM
Simonic
united kingdom
Hi Gents, Thank you both for replying.I'm not in a positon to post any pics at this time as the car is 50 miles away from me. However.......John acting on your info i asked the mechanic who is working on the car to give the block a good scrubbing up near to the pressure sender unit and hey presto we found the correct number.It's pretty faint but good enough for a positive id. Thank you both for your help
Best Wishes
Simon
