'69 383 replacing heads. Which gaskets to get? #1213537
04/10/12 01:12 PM
04/10/12 01:12 PM
Dallas, Wisconsin
BurntOrange Offline OP
Dallas, Wisconsin
I must have a burnt valve on the pass side in my Fury. It misses and "chuffs" out right side tailpipe. I am going to throw on some rebuilt 516s I have laying here. Are the P4286754 http://www.summitracing.com/parts/DCC-4286754/
gaskets as good as they've always been?
Which valley pan has best quality?
Fel-Pro QMS96007 http://www.summitracing.com/parts/FEL-MS96007/
Mopar Performance P4286825 http://www.summitracing.com/parts/DCC-4286825/
Re: '69 383 replacing heads. Which gaskets to get? [Re: BurntOrange] #1213538
04/10/12 01:42 PM
04/10/12 01:42 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd use the standard Steel shim gaskets. the Fel-Pros are like .039 fat and might drop your compression a tad.
Coming soon!!!!
Re: '69 383 replacing heads. Which gaskets to get? [Re: Mr.Yuck] #1213539
04/10/12 01:48 PM
04/10/12 01:48 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
I would add it would be a good idea to paint both sides of the shim aluminum. Adds to a good seal big time.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: '69 383 replacing heads. Which gaskets to get? [Re: Mr.Yuck] #1213540
04/10/12 01:51 PM
04/10/12 01:51 PM
Dallas, Wisconsin
Dallas, Wisconsin
I'm looking at the Felpro Valleypan
Re: '69 383 replacing heads. Which gaskets to get? [Re: DARTH V8Я] #1213541
04/10/12 02:01 PM
04/10/12 02:01 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
I am in the process of fixing a botched motor build...builder F*^%$d me over...and after that will use the steel shims myself. By "painting" both sides what are you using? Upon tear down I noticed that my shims looked like someone had "buttered" them with some type of blue type dye/paint. Not real thick mind you. Just not bare metal looking. What do you recommend for the paint as I like the idea of a good seal. By the way...383 with re-worked 516 heads........
Re: '69 383 replacing heads. Which gaskets to get? [Re: CR8CRSHR] #1213542
04/10/12 02:17 PM
04/10/12 02:17 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
That blue stuff is that insta-gasket/seal stuff. I don't like it.. soley becouse I can never get a even coat. That imo equals leaks. I just use any generic aluminum spray bomb and put a even coat on both sides. It just adds a very thin outer layer and helps the gaskets from moving around after the heads are bolted on, and gives a great positive seal. Never had a problem that way in 20 years. Had those shims holding back some crazy compression too.
Re: '69 383 replacing heads. Which gaskets to get? [Re: CR8CRSHR] #1213543
04/10/12 02:17 PM
04/10/12 02:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I use spray copper coat .
Re: '69 383 replacing heads. Which gaskets to get? [Re: JohnRR] #1213544
04/10/12 02:46 PM
04/10/12 02:46 PM
pa
73roadbird Offline
73roadbird  Offline
pa
Mopar uses a stuff to coat the multi layer headgaskets on the 2.0 and 2.4 motors. Can get it at the dealer. Have done many headgaskets at the dealership and in my own business with great results, can't see why it wouldn't work for your situation. Comes in a spray can.
Re: '69 383 replacing heads. Which gaskets to get? [Re: 73roadbird] #1213545
04/10/12 08:38 PM
04/10/12 08:38 PM
Dallas, Wisconsin
Dallas, Wisconsin
Which valley pan is recommended?
Re: '69 383 replacing heads. Which gaskets to get? [Re: BurntOrange] #1213546
04/10/12 08:41 PM
04/10/12 08:41 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Fel-Pro Q1214 - Fel-Pro Performance Valley Pan Gasket Sets From Summit.
