best way to slow a car down other than throttle stop #1211899
04/07/12 06:20 PM
04/07/12 06:20 PM
High Ridge MO.
MOPARCHAS Offline OP
High Ridge MO.
NHRA license has expired and don't want to spend all the money and time to renew it for as little as I go racing
just asking in case they tell me to slow it down
thanks Charlie 9.61@138.27
Re: best way to slow a car down other than throttle stop [Re: MOPARCHAS] #1211900
04/07/12 06:28 PM
04/07/12 06:28 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
How much do you need to slow down? Easy way is a mechanical throttle limiter, like a bolt under the pedal or on carb to limit the opening.
Brian Dunnigan
Re: best way to slow a car down other than throttle stop [Re: MOPARCHAS] #1211901
04/07/12 06:41 PM
04/07/12 06:41 PM
Guitar Jones Offline
Have you seen those restrictor plates that you can slide in and out? Takes like 5 minutes to change them.
Re: best way to slow a car down other than throttle stop [Re: Guitar Jones] #1211902
04/07/12 07:11 PM
04/07/12 07:11 PM
Short shift at 3000 RPM.
Re: best way to slow a car down other than throttle stop #1211903
04/07/12 08:38 PM
04/07/12 08:38 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Drop the shift points. Sounds like the perfect car for 10.0 index.
Yeah, it's got a smallblock.
Re: best way to slow a car down other than throttle stop [Re: 340B5] #1211904
04/07/12 08:57 PM
04/07/12 08:57 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: best way to slow a car down other than throttle stop [Re: MOPARCHAS] #1211905
04/07/12 09:49 PM
04/07/12 09:49 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You could add more weight to the trunk/rear of the car.
Re: best way to slow a car down other than throttle stop [Re: 451Mopar] #1211906
04/08/12 12:47 AM
04/08/12 12:47 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: best way to slow a car down other than throttle stop [Re: MOPARCHAS] #1211907
04/08/12 12:59 AM
04/08/12 12:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a mech throttle stop on the car and fine tune
it with the launch and shift rpm... works great...
this is the stop I made to fit my 1050 dom
Re: best way to slow a car down other than throttle stop [Re: MOPARCHAS] #1211908
04/08/12 01:37 PM
04/08/12 01:37 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
If you use a throttle cable this is a simple and easy way to slow your car down by not having the carb open all the way.You still floor the gas pedal but the carb only opens part way. You adjust it by changing the the location of the throttle position holes in the little spacer. I used a little piece of aluminum and drilled some holes to make the spacer....more holes the slower the car.Good luck
Re: best way to slow a car down other than throttle stop [Re: hankcrank] #1211909
04/08/12 01:48 PM
04/08/12 01:48 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
thats a pretty handy Idea, not that I need to slow mine down.
Re: best way to slow a car down other than throttle stop [Re: dartman366] #1211910
04/08/12 06:32 PM
04/08/12 06:32 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
You're only aloud to use body panel washers....sorry, those are the rules.
Re: best way to slow a car down other than throttle stop [Re: MOPARCHAS] #1211911
04/08/12 08:43 PM
04/08/12 08:43 PM
Years ago we reaced a duster with a 440 braaket motor with a M.W. top end on it with both carbs, it was about four tenths under the index to start with. We found that by shifting it higher(7000 RPM instead of 6400 RPM into both second and third instead of lower we could slow it down a tenth. If we shifted it at 5000, 5500 or 6000 RPM it would slow down maybe .030 to .050, not a ful tenth. this was before delay boxes and electronic throttle stops, a long,(1984) long time ago Adding weight is probally the better way, put it in the middle of the car between the axles
