72 Wagon tailgate problems......wagon owners help! #1209890
04/04/12 10:25 PM
04/04/12 10:25 PM
West Virginia
N
NewbombTurkk Offline OP
N
West Virginia
I just bought a 72 T&C Wagon.......
The tailgate swings out fine but for some reason when I move the handle to fold it down, only one side seems to pop open.....I see the linkage moving down inside the gate but I guess it is stuck? How do I go about springing the driver's side open so I can grease it?
What does the Tailgate Lock button do located on the dash. Mine doesn't seem to do anything.....
The window IS supposed to operate using the key right? It works from the dash switch but not the key...my old 69 Buick wagon worked with the key....
Thanks wagon owners! See my 72 Wagon thread over in the General section....
1969 Buick Sportwagon 455 Stage 1 Ram Air SOLD
Nationwise Auto Parts Alumni 1982-1984
Now 1972 El Camino, original 402
Re: 72 Wagon tailgate problems......wagon owners help! [Re: NewbombTurkk] #1209891
04/04/12 11:58 PM
04/04/12 11:58 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I'm pretty sure C's are set up the same way as B's, on mine, the window needs to be fully down for the gate to drop down.
Tailgate lock is just that. Even if your car has manual locks for the main doors, the tailgate will have a power lock. Its not uncommon for the solenoid in the 'gate to rust up. You don't need it for the gate to swing both ways.
Yes, the window should go down with the key.
John
Re: 72 Wagon tailgate problems......wagon owners help! [Re: SattyNoCar] #1209892
04/05/12 05:20 AM
04/05/12 05:20 AM
Washington
69440 Offline
69440  Offline
Washington
C-Bodies don't have the two-way tailgate. They only open like a tailgate, not a door, and yes, the window has to be all the way down in order for the tailgate to open.
Re: 72 Wagon tailgate problems......wagon owners help! [Re: 69440] #1209893
04/05/12 05:54 AM
04/05/12 05:54 AM
Westfield, MA
rbrogle Offline
super street
rbrogle  Offline
super street
Westfield, MA
The tailgate moves both ways on C bodies at least back to '65. Sounds like the lock solenoid is stuck.
Rob '70 Fury III 'vert (GT Clone)was 318 3 on the tree,now 440 automatic '68 300 2 Door HT vinyl/cloth bench '68 Newport Custom 4 Dr. HT, 383/2, FULLY LOADED! '68 New Yorker 4 Door HT, 440/Auto, loaded! 2004 Chrysler 300M Special daily driver
Re: 72 Wagon tailgate problems......wagon owners help! [Re: NewbombTurkk] #1209894
04/05/12 06:00 AM
04/05/12 06:00 AM
places
79powerwagon Offline
places
On my old 72 Coronet, I recall having to lay on the floor inside the car and remove the access/trim panel from the inside (not an easy task) and lubing up mechanisms to get it to work properly. I'd bet your C wagon is no different other than size.
Re: 72 Wagon tailgate problems......wagon owners help! [Re: NewbombTurkk] #1209895
04/05/12 04:15 PM
04/05/12 04:15 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Hey John !...how ya been?
sorry for the post hyjack.....wagons rule!
RIP Monte Smith
