Anyone ever put a 12V Cummins in older Mopar Muscle Car #1208465
04/02/12 07:47 PM
04/02/12 07:47 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
OK, So I've seen a bunch of Duramax Chevy engines in Impala's, and Chevelle's, etc. But I've yet to see any older Mopars with a diesel engine.
I have to admit, the Duramax engine is rather impressive inside the older Chevies - So I know the 5.9L 12V Cummins would also be equally, if not even MORE impressive in an older Mopar.
I've seen the older Rat Rod from the Montana 'Welder Up' show, (that has the 5.9L), and it's awesome, but it's just not a Mopar Muscle Car.
Anyone ever done this with an older Mopar??????
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: 68Bullit] #1208466
04/02/12 08:15 PM
04/02/12 08:15 PM
vashon island washington
hunterstroble Offline
Not a mopar, but I saw a buick rivera in hotrod or car craft doing a burn out. Said it had a 12v cummins.
1969 Dodge dart 500 stroker 1973 Dodge Challenger 440
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: 68Bullit] #1208467
04/02/12 08:15 PM
04/02/12 08:15 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
There was a member who posted that he put a 4cyl cummins into his mopar wagon if memory serves. The 4 banger cummins weighs about as much as a big block, with a 5.9 cummins being near 1000lbs. The issue is getting the front end to take that size and weight combined with the expense of buying a 5.9 cummins. I bet it would be easier in a chevy size-wise with one of their v8 diesels.
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: hunterstroble] #1208468
04/02/12 08:17 PM
04/02/12 08:17 PM
IN
ahy Offline
ahy  Offline
IN
Considering even an early 3/4 ton PU chassis was maybe marginal in the front suspension strength department with the heavier engine, it would take a lot of changes to make a car front end live.
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: DaytonaTurbo] #1208469
04/02/12 08:50 PM
04/02/12 08:50 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Here ya' go........... Linky
John
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: 68Bullit] #1208470
04/02/12 08:56 PM
04/02/12 08:56 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Don't forget to check out the you tube 71 ish monte carlo with the 5.9 cummins.
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: SattyNoCar] #1208471
04/02/12 09:02 PM
04/02/12 09:02 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
That car is pretty cool. Nice workmenship
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: Dougsmopars] #1208472
04/02/12 09:57 PM
04/02/12 09:57 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
theres a 73 340 roadrunner running around here with a 3.9 cummins in it.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: mopars_1] #1208473
04/02/12 10:02 PM
04/02/12 10:02 PM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
This was started a while back, and I haven't seen any recent updates. And he was progressing so well.
http://www.rattlerod.blogspot.ca/
Peter
'65 300 'vert 413/4spd
'18 Challenger R/T Shaker
'19 Durango R/T
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: DaytonaTurbo] #1208474
04/02/12 10:32 PM
04/02/12 10:32 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Interesting. What years did they make the 4bt?
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: 68Bullit] #1208475
04/02/12 10:36 PM
04/02/12 10:36 PM
Manitoba, Canada
Manitoba, Canada
Not sure on the years, but it was only installed into commercial vehicles. Stuff like delivery trucks, etc. Makes them a bit difficult to find.
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: 300rag] #1208476
04/02/12 10:55 PM
04/02/12 10:55 PM
Lake View, IA
Deans68plym Offline
Deans68plym  Offline
Lake View, IA
I`m the guy with the 4BT in my `68 Satellite Sport Wagon. I first drove it two years ago, Dec. `09. Have put almost 32,000 miles on it. Ran a 727 with 2:76 gears for 28,000 mi. and then switched to a G 360 5 speed last winter. Fuel mileage is now up to consistent 30mpg, hoping for more. Still using the smallblock torsion bars, just screwed up a little tighter.
I dont know about the added weight of the 6BT in a car without swapping the front suspension to something heavier. And finding room for the oil pan and the radiator will be tough.
On a different note, a little over a year ago I dropped a 6BT/727 in my girlfriends `89 2wd 150 Ramcharger. I used 1 ton front coils and cut 1 1/2 rounds off. It sits the right height and rides nice. 23 mpg everyday.
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: 68Bullit] #1208477
04/03/12 11:03 AM
04/03/12 11:03 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
There was one in a Monte Carlo of all things, but unfortunately the 5.9 ISB is just a BAD idea for any car. Unlike the Duramax, the Cummins is much longer, taller and way, way heavier and there is no way you could make one handle decently and even taking the weight would require a complete redesign of the front suspension.
...then you hafta move the firewall and deal with the height. I'm a big fan of the Cummins and I currently have four Cummins powered Rams, but putting it in a car is just a poor fit. Sure it CAN be done, but it doesn't make any real sense.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: Deans68plym] #1208478
04/03/12 11:09 AM
04/03/12 11:09 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
I am thinking about doing almost the same, 85 D100. One thing I am on the wall about, do the 1/2 ton wheel bearings hold up? And how is the front tire wear? What tires are you using? Crossmember changes needed?
Not planning any heavy use, trips to the dump, maybe some light towing.
A friend bought the perfect donor Saturday, 93 D250 CTD/518, very rusty. $1300, I think I can get a deal. Runs and drives.
It takes gasoline to interest me.
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: VL21] #1208479
04/03/12 06:22 PM
04/03/12 06:22 PM
DPelletier Offline
DPelletier  Offline
I would use all the suspension, driveline and related components from the D250. The Cummins is over 1100 lbs fully dressed and routinely trashes front end components, ball joints, shocks and tires in my 1 ton trucks. No way I'd run a 5.9 CTD without having load range E tires, either.
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: VL21] #1208480
04/03/12 09:23 PM
04/03/12 09:23 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The Cummins Express is a guy who put one in a '79 D100 Li'l Red Express. Google it and check out the vids on you tube..Rat rod guys are also using them.
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: Deans68plym] #1208481
04/03/12 10:15 PM
04/03/12 10:15 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Ok so how much needs to be done to one of 4BT's to make good quarter mile times?
Take a look at this video of the Camaro and tell me what you think he has done to get the 7.97 1/8 mile times. 7.97 in the eighth should equate to about 12.40 in the quarter mile, correct?
If he has a steep enough gearset, could the 4BT be kept mostly stock?
http://www.youtube.com/watch?v=nUiDQd2NZpU&feature=related
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: 68Bullit] #1208482
04/04/12 12:56 AM
04/04/12 12:56 AM
Manitoba, Canada
Manitoba, Canada
If you look up the HP specs on the 4bt you will see it is not a power house by any means.
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: DaytonaTurbo] #1208483
04/04/12 09:53 AM
04/04/12 09:53 AM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Correct. But did you look at the video of the Camaro? he turned a 7.97 in the eighth. That puts him around mid 12's in the 1/4.
That engine stock wouldn't turn those times would it? Unless he's geared? And/or has other mods, maybe?
Re: Anyone ever put a 12V Cummins in older Mopar Muscle Car [Re: DaytonaTurbo] #1208484
04/04/12 10:00 AM
04/04/12 10:00 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
But it was not set up that way stock.
Add some RPM (gov. spring kit) fuel and air it will impress you. Down side? Rough shaking at start and turn off.
I have one that is factory rated at 130 HP and 400 or 440 torque. I added gov spring kit and a fuel plate.
