Cam swap 72 Satellite engine in car q #1207351
04/01/12 06:02 AM
04/01/12 06:02 AM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
Hi
I want to swap the cam on my 72 Satellite, with the 440 still in the engine bay. Is it possible or will there be clearance problems with the radiator support?
thanks, Michail
Re: Cam swap 72 Satellite engine in car q [Re: 440sat72] #1207352
04/01/12 06:30 AM
04/01/12 06:30 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The rad support shouldn't be in the way at all, but the rad, grill, front bumper and hood latch might.
Re: Cam swap 72 Satellite engine in car q [Re: 440sat72] #1207353
04/01/12 10:28 AM
04/01/12 10:28 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Rad must come out. There maybe just enough room to squeak it by the front valance support and the grill maybe just far enough away. Take your time.
Re: Cam swap 72 Satellite engine in car q [Re: DANA60] #1207354
04/01/12 09:02 PM
04/01/12 09:02 PM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
I will take out the rad and the grill but it looks like the valance support might be the problem ... I hoped that someone here had done that kind of swap and could tell me if I am heading for trouble
Re: Cam swap 72 Satellite engine in car q [Re: 440sat72] #1207355
04/01/12 09:10 PM
04/01/12 09:10 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Once the first 4 journals are out, then you can do some careful tilting to help clearing the annoying sheet metal at front.
Re: Cam swap 72 Satellite engine in car q [Re: 440sat72] #1207356
04/01/12 11:08 PM
04/01/12 11:08 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i did the cam in my 69 satellite so i think you can also getting past the support and had enough room before the grill.the cam is like 24" long so measure in front of the engine from the timing cover.
Re: Cam swap 72 Satellite engine in car q [Re: buildanother] #1207357
04/02/12 08:17 AM
04/02/12 08:17 AM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
With tilting you mean tilting the engine?
Re: Cam swap 72 Satellite engine in car q [Re: 440sat72] #1207358
04/02/12 08:55 AM
04/02/12 08:55 AM
chicagoland,usa
chicagoland,usa
No, I mean you can tilt the cam slightly-carefully because the rearmost journal is much smaller than rest of the journals.
Re: Cam swap 72 Satellite engine in car q [Re: buildanother] #1207359
04/05/12 12:06 AM
04/05/12 12:06 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Radiator support wont be a problem. Just pull the radiator and youre there. Ive done it on a 71 RR 2 times with no concerns
