Rear end housing welding #1207207
03/31/12 10:31 PM
03/31/12 10:31 PM
oklahoma
forphorty Offline OP
oklahoma
I have an 8.75 housing i am narrowing. I have a great deal of experience welding sheetmetal(I work in a body shop). 1/4 inch axle tubes,not so much. Looking for some opinions on if a Miller 175 mig would be acceptable for welding the ends on. I believe the machine has .023 wire in it at the moment. Since it is the shops welder, I probably wouldn't want to change the wire size unless i have to. Is preheating of any benefit in this instance?
Re: Rear end housing welding [Re: forphorty] #1207208
03/31/12 11:38 PM
03/31/12 11:38 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not sure why you said 1/4" axle tubes, I thought most OEM tubes are 3/16", the ends however are thicker, and a 220V 175 amp quality machine would IMO be the min needed for quality welds, I would definitely use something thicker then .023 wire, and a mix gas of Ar/CO2, and some preheating would help, especially since it would unlikely add to any warpage issues with just a housing end weld.
Re: Rear end housing welding [Re: forphorty] #1207209
03/31/12 11:50 PM
03/31/12 11:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a 185 (220v) mig to do that all the time...
I did the 9" thats in my Rampage plus I will be
doing a 9" next week, both have thicker tubes than that...
I use 75/25 on the mig
EDIT
I would get a spool of wire .030 and tip to match
Re: Rear end housing welding [Re: MR_P_BODY] #1207210
04/01/12 09:03 AM
04/01/12 09:03 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I do 3-4 9 inch a year with a similar size welder and 0.23 wire. I like the .023 on the small welder because you can get lots of heat without too much wire. Just chamfer back the edges and go nice and slow. I only do maybe 1 1/2 stitches and go back and forth from end to end so you don't create too much heat on one end because it will pull. The thing I didn't hear you mention was do you have a jig to do this? I would not do this without one. In all the housing I have done I have never seen one that was straight enough to just weld new ends on or even cut a piece out and line the ends up. I have no doubt many will say they have done it without.
Re: Rear end housing welding [Re: MR_P_BODY] #1207211
04/01/12 09:29 AM
04/01/12 09:29 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I cut the ends off my 8 3/4 25 years ago. Put the ends in the lathe and squared them. Squared the cuts on the housing with a square. Beveled them and welded them on. I still own the car ,street and 11.0 passes never a problem. Since then I have access to a line-up bar and pucks. The ones I've done with it appear to line up pretty close before welding with the bar installed.
Doug
Re: Rear end housing welding [Re: mac56] #1207212
04/01/12 09:32 AM
04/01/12 09:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes I do have a jig and yes I bevel the end where
the bearing end welds on
EDIT
This is the one that went into the Rampage... I did
add a gusset on the ladder bar bracket after this
pic(where the lateral link mounts to take flex out
of it
Re: Rear end housing welding [Re: MR_P_BODY] #1207213
04/01/12 09:37 AM
04/01/12 09:37 AM
Illinois
Hurst390 Offline
Hurst390  Offline
Illinois
A jig is necessary but does not eliminate problems....If you cut your tube end off and re-weld just the end back on you will not have as much "pull" when welding..now if you cut the tub upo at the center housing welding will pull that tube way more and then a press is required to straighten the housing..jig'd or not...It doesn't look as good but I just shorten my housing out at the axle tube end to eliminate needing a press...but it doesn't look as good because you end up with the end offset from the axle tube...
80 AMX Barry Allen 420 AMC Iron Heads Jerico 4-speed Advanced clutch 2950# street legal 5.97 115.73 Coles county dragway 10/28/07 9.42 142.96 best in 08(6.00 115.8 1/8) 5.97 116.2 in 09 http://www.youtube.com/watch?v=AXSr201-tmA
Re: Rear end housing welding [Re: Hurst390] #1207214
04/01/12 03:03 PM
04/01/12 03:03 PM
oklahoma
oklahoma
Thanks for the info, guys. I have the alignment bar and pucks.
