Re: Rear end housing welding
[Re: forphorty]
#1207208
03/31/12 11:38 PM
03/31/12 11:38 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Not sure why you said 1/4" axle tubes, I thought most OEM tubes are 3/16", the ends however are thicker, and a 220V 175 amp quality machine would IMO be the min needed for quality welds, I would definitely use something thicker then .023 wire, and a mix gas of Ar/CO2, and some preheating would help, especially since it would unlikely add to any warpage issues with just a housing end weld.
[Re: forphorty]
#1207209
03/31/12 11:50 PM
03/31/12 11:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a 185 (220v) mig to do that all the time... I did the 9" thats in my Rampage plus I will be doing a 9" next week, both have thicker tubes than that... I use 75/25 on the mig EDIT I would get a spool of wire .030 and tip to match
[Re: MR_P_BODY]
#1207213
04/01/12 09:37 AM
04/01/12 09:37 AM
Posts: 507 Illinois
Hurst390
Illinois
A jig is necessary but does not eliminate problems....If you cut your tube end off and re-weld just the end back on you will not have as much "pull" when welding..now if you cut the tub upo at the center housing welding will pull that tube way more and then a press is required to straighten the housing..jig'd or not...It doesn't look as good but I just shorten my housing out at the axle tube end to eliminate needing a press...but it doesn't look as good because you end up with the end offset from the axle tube...
80 AMX Barry Allen 420 AMC Iron Heads Jerico 4-speed Advanced clutch 2950# street legal
5.97 115.73 Coles county dragway 10/28/07
9.42 142.96 best in 08(6.00 115.8 1/8)
5.97 116.2 in 09
http://www.youtube.com/watch?v=AXSr201-tmA
