Re: Sealed Power Main Bearing Help
[Re: JohnRR]
#1206948
03/31/12 04:57 PM
03/31/12 04:57 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
good luck , low deck bearing selection is like 383 piston selection ... it sucks ...
Yeah, that's the truth, but then, for just one moment, there was a stroke of luck with the availability of the Sealed Power 3/4 groove. I guess luck ran out because it looks like they discontinued them. Wish I knew this stuff ahead of time
I figured with the popularity of 383 and 400 block strokers that the market would support this type of bearing, but everybody must favor the full groove I guess.
Gee, guess I need to become independently wealthy so I can buy up all these parts I want before they disappear off the market.
Guess I was hoping that maybe, just maybe, there was one or two sets kicking around the country somewhere on the back shelf of some wharehouse. The parts guys say no, they're not listed so they're not available.
Update: Sealed Power Main Bearing Help
[Re: JohnRR]
#1206950
04/01/12 11:18 PM
04/01/12 11:18 PM
CompSyn
Pacific NW USA
Update: Okay, well it all started when I read in Andy Finkbeiner's latest Max-Performance Big Block book that one vendor was offering 3/4 groove main bearings for both B and RB blocks. This was at the time of the books writing; 2009. So when Summit Racing's online application guide listed a Sealed Power 3/4 groove bearing for the B-bock, I thought this must be it, another option besides full groove. With a little more internet research I found the online Federal-Mogul catalog and looked up the bearing P/Ns. With the actual bearing sizes listed (not found at Summit Racing) I discovered that the Sealed Power P/N 4924M is for RB applications. Summit's application guide lists them for both B and RB applications, which I guess is partly true if one were to bore out mains on the B block to fit the RB bearing size. So unless I'm missing something, the main bearing selection for Chrysler B-blocks is full groove, full grove and full groove. And all this controversy over nothing ![](/ubbthreads/images/graemlins/flame.gif)
Re: Update: Sealed Power Main Bearing Help
[Re: Sixgun]
#1206952
04/02/12 12:41 AM
04/02/12 12:41 AM
CompSyn
Pacific NW USA
Try search engines for old part number, sometimes you can find stuff that way, or even Flea Bag. Rock auto etc.They can't have ALL got used up?
You know, one would think that if a 3/4 groove B-block bearing really did exist at one time, there would be a copy or two collecting dust on a shelf somewhere. I've been looking high and low, but it would help if I had a manufacture and P/N # of this said bearing.
[Re: BradH]
#1206954
04/02/12 07:14 PM
04/02/12 07:14 PM
CompSyn
Pacific NW USA
To my knowledge there's never been a 3/4-groove low-deck main bearing offered. Everyone I know w/ a B-block engine runs a narrow full-groove bearing since the only other option is a 1/2 groove.
The RB engines have always had a wider option for bearing styles & materials. I do run the 3/4-groove FM tri-metals in my 440s.
Who makes a 1/2 groove low deck bearing? I'd go with a 1/2 groove if I could find a set.
[Re: Cab_Burge]
#1206956
04/03/12 01:29 AM
04/03/12 01:29 AM
CompSyn
Pacific NW USA
Half groove would be any stock replacement set what size do you need? I stock most of them
Cool! PM sent ![](/ubbthreads/images/graemlins/thumbs.gif)
