2005 Sebring w/2.7 Question #1206700
03/30/12 08:57 PM
03/30/12 08:57 PM
McGregor,Iowa 52157
500ciDuster Offline OP
McGregor,Iowa 52157
My ole ladies 2005 Sebring,2.7 w/57,000 miles started running rough today so I went to check it out when she got off work,I open the hood while she starts it, runs pretty rough sounds like there is a vacuum leak in the center of the intake area,I follow her home for 10 miles and its blue smoking pretty bad.It did pop the engine light and has always ran great with no problems.
It was running for about 20 minutes total but then it sat for about 10 minutes when I went out to start it and look it over again and it runs perfect with no smoke or roughness.Do these get the intake sucking oil syndrome?Thanx
Mitch
Re: 2005 Sebring w/2.7 Question [Re: 500ciDuster] #1206701
03/30/12 09:08 PM
03/30/12 09:08 PM
places
79powerwagon Offline
places
These are historically horrible engines, and there is PLENTY on the web about them and their short-comings.
Re: 2005 Sebring w/2.7 Question [Re: 79powerwagon] #1206702
03/30/12 09:11 PM
03/30/12 09:11 PM
McGregor,Iowa 52157
McGregor,Iowa 52157
well I read all that stuff before we bought it and it seemed like the earlier ones had some problems but there were some upgrade after a certain year
Re: 2005 Sebring w/2.7 Question [Re: 500ciDuster] #1206703
03/30/12 10:29 PM
03/30/12 10:29 PM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
Look for any cracked vaccum lines and try and spray some carb cleaner around the intake and see if it changes
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: 2005 Sebring w/2.7 Question [Re: sreinheimer] #1206704
03/30/12 10:42 PM
03/30/12 10:42 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
97K on our 04 and zero problems with the engine. Just put on an outer tie rod and the windshield washer pump is intermittent, but has been a real good car!
JB Rhinehart, Realist
A-Body's RULE!
Re: 2005 Sebring w/2.7 Question [Re: 500ciDuster] #1206705
03/31/12 12:54 AM
03/31/12 12:54 AM
indy
E
eds dart Offline
eds dart  Offline
E
indy
The lower intake is plastic and has formed orings on the top and bottom. The intake does not seal a lifter valley like a big or small block, fact is there is no oil near upper or lower intake.Vacumn leak is possible but smokeing/oil problem is something else. I just put a 2001 intrepid with 2.7 back together. crank was bad 2 con rods bad new water pump, chains ,tensoiner and piston rings and she runs great. the motor was sludged up the worst i have ever seen. funny thing, it ran great with only flickering oil light at hot idle. its as much an experiment to see how long it will last. it does get fantastic milage and the Intrepis is a really nice car.
Re: 2005 Sebring w/2.7 Question [Re: eds dart] #1206706
03/31/12 03:30 AM
03/31/12 03:30 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The pcv valve most likely needs changed.
I've been working on a bunch lately.
If the oil doesn't get changed on schedule they will sludge quick.
The last two that I changed out were do to the shop before me doing a T chain gears & heads after the chain broke & not flushing the debris out of the oil pan.
Re: 2005 Sebring w/2.7 Question [Re: BulletBob] #1206707
04/01/12 11:39 AM
04/01/12 11:39 AM
McGregor,Iowa 52157
McGregor,Iowa 52157
Thanx
