Can I get a tunnel to trans output measurment? #1206481
03/30/12 02:21 PM
03/30/12 02:21 PM
Tucson AZ
2
2cudabuck Offline OP
Tucson AZ
Hey, happy Friday to all!! I was hoping some one had their ebody up in the air with their trans in and would give me a measurement from the bottom of the tunnel to the center of the trans output. I have read all the threads (great reading, confusing, but great!) about the output angle and pinion angle relationship, so I'm confident I can get that. I'm just trying to get my trans close to where it should be and secured so I can start a couple of other things. Thanks all!!!
Buck
Buck 67 273 Dart GT 69 RT 440 Charger (SWEET!) 70 318 Cuda 74 Cuda Packin a 426 roller Hemi
Re: Can I get a tunnel to trans output measurment? [Re: 2cudabuck] #1206482
03/30/12 03:21 PM
03/30/12 03:21 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Buck
Non factory trans install.
Re: Can I get a tunnel to trans output measurment? [Re: JohnRR] #1206483
03/30/12 06:07 PM
03/30/12 06:07 PM
Tucson AZ
2
Tucson AZ
oops, sorry, yeah it's a five speed but it is identicle in length to the 904 that came out. I just want to get it in the approximate place it needs to be so I can start mocking up other stuff. So even just looking under there and saying the end of my 904 is about two inches from the bottom of the tunnel would work.
