Re: Subframe connectors any reasons not to have them?
[Re: MidPenMopar]
#1206171
03/29/12 09:12 PM
03/29/12 09:12 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
None that I know of. I had them on my 69 Bee and it was noticeably stiffer.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: dustergirl340]
#1206173
03/29/12 09:21 PM
03/29/12 09:21 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
I've had them on my Duster for almost 10 years now. No cons here. Easier to jack the car up, drives better on the road, launches straighter at the track.
Ok that all sounds pretty positive! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MoparforLife]
#1206176
03/29/12 09:57 PM
03/29/12 09:57 PM
MidPenMopar
Just happen to have a set of competition engineering connectors for B body that I got for my runner and never got to use because I sold the car as a project. PM me if interested.
Ok I PMed you! ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MidPenMopar]
#1206177
03/29/12 10:03 PM
03/29/12 10:03 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Only reason to me is if your building a totally stock original car... this wouldn't fit for your car ![](/ubbthreads/images/graemlins/thumbs.gif)
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 1_WILD_RT]
#1206180
03/30/12 01:06 AM
03/30/12 01:06 AM
MidPenMopar
I pretty much agree with this.. Stu you probably don't drive aggressively enough to justify subframe connectors but if you want to add them I don't see any reason not to... But if your gonna do it 1"x2" material isn't worth the trouble.... most guys use 2"x2" or 2"x3"...
Ok that's what i was looking to find out as to what is the way to go on them. Here's a set that Summit sells for $150.
http://www.summitracing.com/parts/CEE-3117/All/
[Re: DaytonaTurbo]
#1206186
03/30/12 12:47 PM
03/30/12 12:47 PM
Posts: 1,884 Tracy CA
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
I used the 2x3" square tube. Slot open the front part of the rear sub-frame and the square tube slides right in nicely so you can weld it all back together. Only downside to doing it this way is in the back seat feet area the tube comes thru the floor by about 1". It gives a real nice increase in torsional rigidity.
This is the exact way I do it! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MidPenMopar]
#1206187
03/30/12 03:26 PM
03/30/12 03:26 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Be sure to add the 4 torque boxes when you add the sub-frame connectors. You may want to consider putting in a lower radiator support while your under there too.
I set mine back enough to clear the radiator tank on my '68. It's easier to put in that way, less intrusive and can be removed pretty easily in the future should the need arise.
You can see it tieing the bottom of the front frame rails together down in there just in front of the fan belt
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
