Power Brakes and Engine Vacuum? #120591
09/14/08 01:46 PM
09/14/08 01:46 PM
Southwestern Ontario Canada
racealittle Offline OP
What is the minimum vacuum (at idle), required for power brakes to work properly? Thanks
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Power Brakes and Engine Vacuum? [Re: racealittle] #120592
09/14/08 02:40 PM
09/14/08 02:40 PM
IN
ahy Offline
ahy  Offline
IN
I've found they work fine with 12". I wouldn't want to have much less.
Re: Power Brakes and Engine Vacuum? [Re: ahy] #120593
09/14/08 04:09 PM
09/14/08 04:09 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
And if you're worried you can always add a vacuum reserve canister to help with the duties...
Re: Power Brakes and Engine Vacuum? [Re: racealittle] #120594
09/14/08 04:12 PM
09/14/08 04:12 PM
Kirkland, Washington
Pacnorthcuda Offline
I ran a car with 6.5 inches but I really wouldn't recommend it. Without a cannister I would think you would be just fine with 10"
Re: Power Brakes and Engine Vacuum? [Re: racealittle] #120595
09/14/08 04:54 PM
09/14/08 04:54 PM
I need to put good working engine in my Challenger for a while while I decide what to do with the original small block. All I have is big blocks. The smallest cam is a street hemi grind MP.474 280 which makes anywhere from 9 to 12 inches of vacuum depending on idle, neutral, in gear, engine temp etc. It idles nice in gear at 700 rpm or so. I think I have most of what I need to make the swap without grief. My other engine choices would be more fun, but likely unsafe when it comes to stopping. I kind of thought this might be the lowest vacuum required to retain safe and effective power brakes.
Re: Power Brakes and Engine Vacuum? [Re: racealittle] #120596
09/14/08 05:02 PM
09/14/08 05:02 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
I have 8" of vacuum at idle, in gear, with my 440. The power brakes work fine. I do have the engine in a truck with the dual diaphgram brake booster.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: Power Brakes and Engine Vacuum? [Re: Blown_Hemi] #120597
09/15/08 03:09 AM
09/15/08 03:09 AM
Rohnert Park, Ca
ryan053 Offline
ryan053  Offline
Rohnert Park, Ca
My 68 charger has 10.5" at idle and the power brakes work fine.
