Page 3 of 4 1 2 3 4
Re: New Hemi Builds and Swap Thread [Re: Pat7272] #1205762
04/15/12 03:53 PM
04/15/12 03:53 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
The 5.7 car intake has the most torque (08- and prior). The 6.1 intake gives up ~ 5 ftlb to the 5.7 intake down low, but passes it around 5200 and has good power through 6400 or so. The drag pack intake loves RPM and is the best of the carb style intakes, with better high end hp than the two efi intakes. I've heard significantly more than the 6.1 above 7000 on up to 8200. It does however give up significant torque down low to the 6.1 and 5.7.
The LX guys typically do not rev past 6400 with their tuned stock computers, so I'm anxious to see what my ported 6.1 intake will do above 6400.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: New Hemi Builds and Swap Thread [Re: Uhcoog1] #1205763
04/16/12 06:38 PM
04/16/12 06:38 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
A great budget option is a 5.7 eagle intake, if you've got a 5.7 early head with big enough ports (or the intake spacers) or a 6.1 head.
An old style 5.7 intake will not be a limiting factor on most of the hemi swaps in an old car. I've had it go 11.50 @ 117 with a 5.7 392 swap back in 08 @4150 raceweight.
It won't look pretty, but it will work.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: New Hemi Builds and Swap Thread [Re: Uhcoog1] #1205764
04/16/12 06:39 PM
04/16/12 06:39 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: New Hemi Builds and Swap Thread [Re: 65signet] #1205765
04/19/12 10:47 PM
04/19/12 10:47 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
09 GC here 5.7...... Stock exhaust is very restrictive..... I put a full srt8 exhaust on and huge difference...... Stock shorty srt8 headers work great....... With a CAI and 93 diablo tune my porky jeep ran 14.18. Not bad for 4400lbs...... Also runs up to 140mph with ease....... Stock eagle heads flow more than 300cfm..... My stock BB edelbrock heads flow 290..... These small block hemis are the shizzle! I plan a 392 rotating assembly and fully ported eagle heads and maybe run the stock 6.4 hemi VVT cam (580/530) lift and right at 11-1 CR should get me around 450 rwhp....... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: New Hemi Builds and Swap Thread [Re: tpabayflyer] #1205766
04/21/12 02:41 PM
04/21/12 02:41 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Check in with www.modernmoparforum.com its the place for those cars / engines. And no rules...
Re: New Hemi Builds and Swap Thread [Re: mshred] #1205767
04/21/12 03:57 PM
04/21/12 03:57 PM
MN
hemidup Offline
hemidup  Offline
MN
Hey guys,
I know there are various threads on here that cover new hemi builds of various varieties, parts interchangeability, etc. However, I like many others have thought about performing the swap into their cars, yet find it hard to lay out a list of I will need and how much everything would roughly cost. I think that is part of why so many guys stay away from the swap, since they are not sure what is involved.
Anyways, I was thinking that maybe this thread could be a place where people who have retrofitted these engines into the older body styles can post up their builds (i.e. what parts were used in their actual engine build, rough cost if comfortable sharing) as well as what parts were NEEDED to get the engine to work in your car (i.e. special headers, mounts, etc. and what the cost was). I know it might be a lot of info to share, and some may not be willing, but I think it could be a great way to share the potential these motors have and just what is needed to get them running in an older car
If anyone would care to share, im sure I and many others would greatly appreciate it
Dropped a carbed 5.7 in a 1940 2 door Dodge Coupe.
Jerry Williams.
Re: New Hemi Builds and Swap Thread [Re: hemidup] #1205768
04/24/12 02:17 PM
04/24/12 02:17 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Oil pan for dirt modified car...
If you like drag racing, support your local track.
Re: New Hemi Builds and Swap Thread [Re: CHAPPER] #1205769
04/24/12 02:18 PM
04/24/12 02:18 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
2
Re: New Hemi Builds and Swap Thread [Re: CHAPPER] #1205770
04/24/12 02:18 PM
04/24/12 02:18 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
3
Re: New Hemi Builds and Swap Thread [Re: CHAPPER] #1205771
04/24/12 02:21 PM
04/24/12 02:21 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
First design,,,will be making changes I'm sure! Will hold 12 qts. oil.
Re: New Hemi Builds and Swap Thread [Re: CHAPPER] #1205772
04/26/12 01:37 PM
04/26/12 01:37 PM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
If I do end up scoring the 6.1 I'm trying to get, the plan is a single turbo, EFI and going in a 67 GTX.
The build plan is FAST XFI 2.0, stainless valves, LSM custom turbo cam, diamond pistons, Manley H-beam rods, and billet main caps. I'll custom build all the hot and cold side. It will probably get a Garrett GT4718 and air to water intercooler. Will probably end up with a power glide too.
I'm shooting for 800 ant the tire on pump.
Re: New Hemi Builds and Swap Thread [Re: JackGTX440] #1205773
04/27/12 03:08 AM
04/27/12 03:08 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Not really a performance build up except comparing to the stock six banger, but a hemi swap anyway. At first ti seemed like there is no way itr would fit, but in the end the 5.7 out of a 2004 Durango and a 904 trans slipped in there just fine. Had to modify the engine mounts, oil pan/pick up and build new "exhaust manifolds". Solved the fuel iSSue by installing a half gallon auxilar tank in to the engine bay where the original in tank carburator pumps supply the fuel. After that is a MSD EFI pump + rgulator, and the return is to the auxilar tank. Seems to work fine. The wiring and computer came from Bouchillon performance as well as the 2003 "fly by wire gas pedal signal conversion box". Didn't expect much of the combo, but I must say that there truely has happened some progress in the 40 or so years, when the last predecessor was designed! Oh, and almost forgot; the power steering pump puked all the gaskets out of the stock rack & pinion, replaced it with a GM LT1 pump that has lower pressure. Needed new oil lines, drilling the mounting holes bigger and honing the stock pulleys hole bigger to fit the GM pump.
http://kuvablogi.com/blog/24173/7/
Plynouth VIP '67 TT IC EFI
Re: New Hemi Builds and Swap Thread [Re: jyrki] #1205774
04/27/12 07:05 AM
04/27/12 07:05 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I am trying to find out what are good core engines to buy, what to avoid etc. I make billet parts and would like to start branching out into the late Hemi stuff, so I will be needing an engine to start with. I am looking at bringing over an engine or two come middle of the year. The one thing I am noticing is that one thing that might be worthwhile me looking at is timing covers.
Incidently, The companies I use to Sea freight to Australia are based in LA and Indianapolis, so If I could source an engine when the time comes close to those area it would be great.
Alan Jones
Re: New Hemi Builds and Swap Thread [Re: LA360] #1205775
04/29/12 08:29 PM
04/29/12 08:29 PM
Augusta, GA
Lightning Offline
Lightning  Offline
Augusta, GA
I've got a bit of a stupid question....has anybody used a motor plate on new Hemi yet? It seems like it would be easier to mount that way. I'm no expert, I just read a lot of things when I get bored.
Re: New Hemi Builds and Swap Thread [Re: Lightning] #1205776
04/29/12 09:01 PM
04/29/12 09:01 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Here's Mine....
Re: New Hemi Builds and Swap Thread [Re: STEFF] #1205777
04/29/12 09:21 PM
04/29/12 09:21 PM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
I just finished up my build.. take a look. It's a forged 6.1 with ported and nice cam and a Kenne Bell supercharger
Re: New Hemi Builds and Swap Thread [Re: STEFF] #1205778
04/30/12 10:52 AM
04/30/12 10:52 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Here's Mine....
Hey steff, whats your motor build going to be this time around?
You basically proved to me that I don't want to use stock rods
Re: New Hemi Builds and Swap Thread [Re: AlexP] #1205779
04/30/12 07:09 PM
04/30/12 07:09 PM
STEFF Offline
STEFF  Offline
389", more comp, big cam, fixed 6.1 heads.....should be fun!
Re: New Hemi Builds and Swap Thread [Re: STEFF] #1205780
05/01/12 10:21 AM
05/01/12 10:21 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Offset ground or scat crank ?
Re: New Hemi Builds and Swap Thread [Re: AlexP] #1205781
05/01/12 10:25 AM
05/01/12 10:25 AM
STEFF Offline
STEFF  Offline
Offset ground 6.1 crank....3.68 stroke x 4.100 bore
Page 3 of 4 1 2 3 4
