Need help identifying an H wheel date code #1201368
03/22/12 03:31 PM
03/22/12 03:31 PM
Plymouth, MI
HotRod20 Offline OP
HotRod20  Offline OP
Plymouth, MI
Heres a couple pics. the stamping shows :3 then, M4 over a 7, a 1 and then 19 and then 60.
Thanks HR 20
Re: Need help identifying an H wheel date code [Re: HotRod20] #1201369
03/22/12 03:40 PM
03/22/12 03:40 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Thanks HR 20
Not an H wheel that fit Hemi and A12 cars, all H wheels were made in the M5 plant
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Need help identifying an H wheel date code [Re: AZ_A12_BEE] #1201370
03/22/12 04:19 PM
03/22/12 04:19 PM
Detroit Rock City!
silent-H-wheel Offline
Detroit Rock City!
In addition to the above, the "7" denotes it was made in a year ending in 7, thus 1967 or 1977, both too far away from 1969-71, when most "large H" stamped wheels were used. I don't believe Mopar steel wheels made prior to 1969 had flat areas between the lug holes...most had bumps. At least, the 1968 Hemi cars were that way. If it has a small H stamped between the lug holes, then it's a later H wheel, most likely from 1977.
John
2019 Jeep Grand Cherokee SRT
2018 Challenger SRT Demon
Re: Need help identifying an H wheel date code [Re: silent-H-wheel] #1201371
03/22/12 05:01 PM
03/22/12 05:01 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I would guess there is also a full part # under that rust by the valve stem
Re: Need help identifying an H wheel date code [Re: AZ_A12_BEE] #1201372
03/23/12 03:34 PM
03/23/12 03:34 PM
Plymouth, MI
HotRod20 Offline OP
HotRod20  Offline OP
Plymouth, MI
Well it does not have a part number near the valve stem. I cut off the stem and cleaned it well. Here is a picture of the "H". I guess it may be a Jan, 19 th 1967 15 x 6 wheel. Any one can chime in on this. Thanks HR 20.
Re: Need help identifying an H wheel date code [Re: HotRod20] #1201373
03/23/12 07:28 PM
03/23/12 07:28 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
H is too small, its a later 77 wheel
Re: Need help identifying an H wheel date code [Re: AZ_A12_BEE] #1201374
03/23/12 07:35 PM
03/23/12 07:35 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
'69 model year "H" wheel & I'm not sure '67 model year had a "H" wheel, especially with a flat center.
Re: Need help identifying an H wheel date code [Re: 6bblgt] #1201375
03/23/12 07:39 PM
03/23/12 07:39 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Notice the center on this 1968 model year 15x6.0 wheel used on HEMI cars. no "H"
Re: Need help identifying an H wheel date code [Re: 6bblgt] #1201376
03/23/12 07:40 PM
03/23/12 07:40 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Correct no H wheel with a 67 date code, I have seen this "middle sized" H before in late 70s wheels, also a real H wheel has no additional stampings on the face like his wheel has, sorry Hotrod but you do not have an H wheel, you have a wheel with an H
Re: Need help identifying an H wheel date code [Re: AZ_A12_BEE] #1201377
03/23/12 09:27 PM
03/23/12 09:27 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's my small H wheels with a part number by the valve stem....these will work for my A12 (someday ), the price was right. Perfect 50/50 wheels....50 MPH @ 50 Feet you won't know the difference
Re: Need help identifying an H wheel date code [Re: A12] #1201378
03/23/12 09:28 PM
03/23/12 09:28 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
the part number by the valve stem hole
Re: Need help identifying an H wheel date code [Re: A12] #1201379
03/24/12 12:39 PM
03/24/12 12:39 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Here is a real deal 5-14-69 H-wheel I just bought for my Bee. You can see the H from a mile away compared to the later small H-wheels.
Re: Need help identifying an H wheel date code [Re: 70440+6bbl] #1201380
03/24/12 09:05 PM
03/24/12 09:05 PM
Plymouth, MI
HotRod20 Offline OP
HotRod20  Offline OP
Plymouth, MI
Thanks for all the info....yup ...looks like a wheel with an H.Not an H wheel. Good for a spare, or roller for the next project.
HR 20.
