Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?!
[Re: Labratt]
#1198621
03/17/12 09:16 PM
03/17/12 09:16 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I get them closer than 1 gram EDIT since its a external balance balancer ...yes it should be balanced with it
[Re: Labratt]
#1198627
03/18/12 12:31 AM
03/18/12 12:31 AM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
My K1 rods (6.535 x 2.20) were within +- 0.5 gram as delivered. Thanks Dan at Performance Only for the rods and 4.15 K1 crank...
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: Labratt]
#1198628
03/18/12 02:56 AM
03/18/12 02:56 AM
dogdays
You're getting confused by two different situations. When the assembly is balanced your machinist will weigh everything and correct any differences. But a small difference in rod or piston weight is not the reason to balance with harmonic damper and flywheel. The reason to balance with the entire rotating assembly is because it gives better results, closer to "perfect". This is true even for an internally balanced engine. Sounds to me that your machinist is pretty good and trying to do a good job for you. R.
[Re: Labratt]
#1198632
03/18/12 06:12 PM
03/18/12 06:12 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I had to get two replacement Eagle H beams to make a set again. I gave them the numbers off the weight card but the rods I got were 10 grams heavier on the big end than the old ones. I bought these things about 12 years ago so returning them wasn't an option and if you've ever seen these rods you know you really can't take anyweight off them. My machinist suggested to just add the 10 grams to the bob weight on one journal and install those two rods on the same journal. He says he's done it before without a problem and everything balances OK. So that's what I did.
[Re: Labratt]
#1198634
03/19/12 02:00 AM
03/19/12 02:00 AM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
BTW...it is a FORGED factory crank..so it's an internally balanced engine from the factory.
And that's the way it should be when your machinist is done . If he wants the balancer to confirm that is it truly neutral then that is one thing but if he is planning to balance the crank with it attached to the crank then that is something I would be questioning no matter who the builder is.
As far as the rods being out 5 grams , NOW you know why you got a GOOD DEAL on them .
