5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! #1198620
03/17/12 09:13 PM
03/17/12 09:13 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
After weighing my new K-1 H-Beam rods,the lightest to heaviest is a difference of 5 grams. Should that be a concern when having the rotating assembly balanced? My friend from Ohio says NO...but,my machinist seems to think it should be balanced with the balancer(externally) Who's right? I didn't think 5 grams was enough to worry about...since they have to be equalized anyway! School me on this,"Engine Masters"!
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: Labratt] #1198621
03/17/12 09:16 PM
03/17/12 09:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I get them closer than 1 gram
EDIT
since its a external balance balancer ...yes it should
be balanced with it
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: MR_P_BODY] #1198622
03/17/12 09:51 PM
03/17/12 09:51 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
[since its a external balance balancer ...yes it should
be balanced with it
Cast Crank?
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: MR_P_BODY] #1198623
03/17/12 09:55 PM
03/17/12 09:55 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Externally balanced?? Cast Crank motor? Anyways......trust Shawn.
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: STEFF] #1198624
03/17/12 10:03 PM
03/17/12 10:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
trust Shawn.
100%
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: Labratt] #1198625
03/17/12 11:59 PM
03/17/12 11:59 PM
The Hi Po industry standard has been + or - one gram on all roatating parts.Shoot for + .5 grams to - .5 grams On connecting rods you need to know which end the weight is off on, IE big end or wrist pin end and adjust as needed, find the lightest one and make all the other match it
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: Cab_Burge] #1198626
03/18/12 12:23 AM
03/18/12 12:23 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Questions done!...I DO trust Shawn!..and his judgement on what to do!
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: Labratt] #1198627
03/18/12 12:31 AM
03/18/12 12:31 AM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
My K1 rods (6.535 x 2.20) were within +- 0.5 gram as delivered. Thanks Dan at Performance Only for the rods and 4.15 K1 crank...
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: Labratt] #1198628
03/18/12 02:56 AM
03/18/12 02:56 AM
dogdays Offline
dogdays  Offline
You're getting confused by two different situations.
When the assembly is balanced your machinist will weigh everything and correct any differences. But a small difference in rod or piston weight is not the reason to balance with harmonic damper and flywheel.
The reason to balance with the entire rotating assembly is because it gives better results, closer to "perfect".
This is true even for an internally balanced engine. Sounds to me that your machinist is pretty good and trying to do a good job for you.
R.
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! *DELETED* [Re: dogdays] #1198629
03/18/12 12:58 PM
03/18/12 12:58 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Post deleted by mr_340
Floyd Lippencott IV
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: mr_340] #1198630
03/18/12 02:49 PM
03/18/12 02:49 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the info,dogdays! I just thought a 5 gram difference was pretty substancial..especially when I see some companies guaranteeing +/- 1 gram in a set of "matched" rods.I got a VERY GOOD price on them,from a VERY RESPECTED engine builder in Ohio! I'm thinking,to a GOOD machinist..which I know Sean is,it should be no big deal! If using the Fluidamper gives it a more precise balance,I'm all for it! BTW...it is a FORGED factory crank..so it's an internally balanced engine from the factory.
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: Labratt] #1198631
03/18/12 06:04 PM
03/18/12 06:04 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Randy, like Steff and Raff have said, trust Shawn.
Randy
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: Labratt] #1198632
03/18/12 06:12 PM
03/18/12 06:12 PM
Guitar Jones Offline
I had to get two replacement Eagle H beams to make a set again. I gave them the numbers off the weight card but the rods I got were 10 grams heavier on the big end than the old ones. I bought these things about 12 years ago so returning them wasn't an option and if you've ever seen these rods you know you really can't take anyweight off them. My machinist suggested to just add the 10 grams to the bob weight on one journal and install those two rods on the same journal. He says he's done it before without a problem and everything balances OK. So that's what I did.
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: Dartin] #1198633
03/19/12 01:17 AM
03/19/12 01:17 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Hey..just saw that "pretty" motor on Friday..when I dropped off my Diamond pistons,that have to be sent out for a .005 coating on the skirts! Apparently,when the motor was rebuilt 6 yrs. ago,a torque plate was not used,and Shawn measured the cylinders up to 4.361-.362..on a .040 over-bore...and without a plate bolted up. He said once the plate was installed,and torqued to spec...the cylinders would measure even bigger! So...I have 2 options...bore it out,and replace my GOOD pistons,or bore and hone to 4.365...and coat the piston skirts,which I opted for. He said he's had excellent results using this method! Sounds good to me!
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: Labratt] #1198634
03/19/12 02:00 AM
03/19/12 02:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
And that's the way it should be when your machinist is done . If he wants the balancer to confirm that is it truly neutral then that is one thing but if he is planning to balance the crank with it attached to the crank then that is something I would be questioning no matter who the builder is.
As far as the rods being out 5 grams , NOW you know why you got a GOOD DEAL on them .
Re: 5 GRAM DIFFERENCE ON ROD WEIGHTS?!?! [Re: JohnRR] #1198635
03/19/12 11:29 AM
03/19/12 11:29 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the insight,John! I'm sure Shawn knows what he's doing...and will balance everything properly! I will have a discussion with him about using the balancer,as well! He's been building HIGH HORSEPOWER motors for years...with EXCELLENT results!
