Page 2 of 5 1 2 3 4 5
Re: Info on these three dimples?? 1970 71 E body [Re: Troy] #1198518
03/17/12 10:58 PM
03/17/12 10:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The cars were not built in order of VIN.
They were not built on their SPD in a lot of cases, often not even the same month as the SPD.
Incoming stock was mixed with old.
There are too many variables, there is no way to pin down an exact change date because there wasn't one.
Re: Info on these three dimples?? 1970 71 E body [Re: Alaskan_TA] #1198519
03/17/12 11:42 PM
03/17/12 11:42 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I agree that you are not going to pin down a date, but there are going to be some specifics that can be said about the 3 "dimple" upper firewall on a '70 e-body.
Did LA use this part? With e-body production ending in May '70 - did they recieve any of these firewall panels?
Since it appears April in Hamtramck was the some do & some don't "month" are there any built in March with the "dimples" (& I'd say any in Feb. '70 or earlier would be suspect), or any in May without the "dimples" (later w/o would be suspect).
Re: Info on these three dimples?? 1970 71 E body [Re: fireeng] #1198520
03/17/12 11:48 PM
03/17/12 11:48 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's the firewall on my '71 BH23C1B "pilot" car - it appears to have been built in April '70. (not sure if it had "dimples")
When do they start production on the next model year?
My 71 challenger (with dimples) was built in sept of 70. I thought that was an early build for a 71.
"Pilot" cars are built pre-production, production of 1971 model year Chrysler Corp. cars started in August of 1970.
Re: Info on these three dimples?? 1970 71 E body [Re: Troy] #1198521
03/18/12 12:38 AM
03/18/12 12:38 AM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
OK...who can tell me that these three dimples are for? What plant, what dates were they used? Any info will help. Some cars have them and some don't.....whats up!!
The three dimples are located on the passengers side, straight up from the blower motor on the cowl.
TROY..
Here is a thread from 3 years back this same question was asked. There is some good info & photos here. In 70 and 71, more & more emission stuff was being required with California cars being about 2 years ahead of the other states..
Also around that time (July, 71) Chrysler was shutting down their Commerce, CA factory just off the 5/710 interchange. So their other factories located outside of CA had to be capable of building cars to meet the CA emission requirements during this changeover..
https://board.moparts.org/ubbthreads/showflat.php?Number=5325096
Just my $0.02..
Re: Info on these three dimples?? 1970 71 E body [Re: Sinitro] #1198522
03/18/12 01:12 AM
03/18/12 01:12 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The LA plant stopped producing E-bodies some time in May of 1970.
Hamtramck produced N95 E-body models for the 1970 model year also.
If you have a March 1970 or later E-body, note the SPD on your tag / broadcast sheet, the actual build month from your original door sticker & whether it has the dimples or not. That will be a start.
Re: Info on these three dimples?? 1970 71 E body [Re: 6bblgt] #1198523
03/18/12 01:16 AM
03/18/12 01:16 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
This is what I'm looking for. I believe that there might not be a definite date but just looking for a ball park date will work.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Info on these three dimples?? 1970 71 E body [Re: Troy] #1198524
03/18/12 01:26 AM
03/18/12 01:26 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
4 - 70 Mylar on that one Troy?
Re: Info on these three dimples?? 1970 71 E body [Re: Alaskan_TA] #1198525
03/18/12 01:30 AM
03/18/12 01:30 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
That is just a random photo that I have collected..
Re: Info on these three dimples?? 1970 71 E body [Re: Troy] #1198526
03/18/12 01:33 AM
03/18/12 01:33 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
With all of this being said....is there anyway by looking at a dash VIN number can you figure out if that car should have the dimples?
Re: Info on these three dimples?? 1970 71 E body [Re: Troy] #1198527
03/18/12 01:51 AM
03/18/12 01:51 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes & No. A dash VIN# will give you a SPD, but not an actual production date.
It should at least put it in should/might/shouldn't category. I have not cataloged any info on this, but it sounds like GG has.
Re: Info on these three dimples?? 1970 71 E body [Re: Troy] #1198528
03/18/12 01:53 AM
03/18/12 01:53 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Nope.
Re: Info on these three dimples?? 1970 71 E body [Re: Troy] #1198529
03/18/12 02:07 AM
03/18/12 02:07 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Hi Scott, Hope all is well.
The Hemi car picture I posted had a date of 808 and there are no dimples. I have been looking and many cars recently and I can't find and clear cut date on when these were used.
are you sure that's not B08?
Re: Info on these three dimples?? 1970 71 E body [Re: 6bblgt] #1198530
03/18/12 02:14 AM
03/18/12 02:14 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
My old R/T SE has a SPD of 723 & does not have the dimples... I guess it's suspect.....
Re: Info on these three dimples?? 1970 71 E body [Re: 6bblgt] #1198531
03/18/12 02:22 AM
03/18/12 02:22 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
I have three pictures of the tag and they all look like 808. I don't know if you saw this car Dan. It was that survivor Hemi Challenger that showed up late at the last Spring Fling. Very cool car!!
Re: Info on these three dimples?? 1970 71 E body [Re: 1_WILD_RT] #1198532
03/18/12 02:50 AM
03/18/12 02:50 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I was trying to point out that there is some rhyme/reason and/or pattern to the dimple vs. no-dimple. The "maybe" period could be the last 3 months of the year. Your "former" car could be the lone exception for the end of July '70, or the last month of production might all be without.
My 702 SPD '70 Challenger R/T was finished at least 2 weeks late. It has many '71 attributes.
My 801 SPD '71 Barracuda was assembled at least 2 months early. It has many '70 attributes.
Re: Info on these three dimples?? 1970 71 E body [Re: Troy] #1198533
03/18/12 02:52 AM
03/18/12 02:52 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes, and it's B08.
Re: Info on these three dimples?? 1970 71 E body [Re: 6bblgt] #1198534
03/18/12 03:09 AM
03/18/12 03:09 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
ok..... I must have three real bad pictures. I would email you my photos but it does not seem to work.
Re: Info on these three dimples?? 1970 71 E body [Re: Troy] #1198535
03/18/12 04:20 AM
03/18/12 04:20 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Sorry about that. There's sort of a blob of paint right on the SPD there and my camera was not set at the high quality setting.
Re: Info on these three dimples?? 1970 71 E body [Re: autoxcuda] #1198536
03/18/12 04:39 AM
03/18/12 04:39 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Re: Info on these three dimples?? 1970 71 E body [Re: Alaskan_TA] #1198537
03/18/12 10:24 AM
03/18/12 10:24 AM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
The SPD on my pink car is 324 but the door mylar is 4-70. It has the dimples.
