Re: Info on these three dimples?? 1970 71 E body
[Re: Troy]
#1198518
03/17/12 10:58 PM
03/17/12 10:58 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
The cars were not built in order of VIN. They were not built on their SPD in a lot of cases, often not even the same month as the SPD. Incoming stock was mixed with old. There are too many variables, there is no way to pin down an exact change date because there wasn't one.
[Re: fireeng]
#1198520
03/17/12 11:48 PM
03/17/12 11:48 PM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
Here's the firewall on my '71 BH23C1B "pilot" car - it appears to have been built in April '70. (not sure if it had "dimples")
When do they start production on the next model year? My 71 challenger (with dimples) was built in sept of 70. I thought that was an early build for a 71.
"Pilot" cars are built pre-production, production of 1971 model year Chrysler Corp. cars started in August of 1970.
[Re: Troy]
#1198521
03/18/12 12:38 AM
03/18/12 12:38 AM
Posts: 5,447 So Cal
Sinitro
So Cal
OK...who can tell me that these three dimples are for? What plant, what dates were they used? Any info will help. Some cars have them and some don't.....whats up!!
The three dimples are located on the passengers side, straight up from the blower motor on the cowl.
TROY.. Here is a thread from 3 years back this same question was asked. There is some good info & photos here. In 70 and 71, more & more emission stuff was being required with California cars being about 2 years ahead of the other states..
Also around that time (July, 71) Chrysler was shutting down their Commerce, CA factory just off the 5/710 interchange. So their other factories located outside of CA had to be capable of building cars to meet the CA emission requirements during this changeover..
https://board.moparts.org/ubbthreads/showflat.php?Number=5325096
Just my $0.02..
[Re: Sinitro]
#1198522
03/18/12 01:12 AM
03/18/12 01:12 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
The LA plant stopped producing E-bodies some time in May of 1970. Hamtramck produced N95 E-body models for the 1970 model year also. If you have a March 1970 or later E-body, note the SPD on your tag / broadcast sheet, the actual build month from your original door sticker & whether it has the dimples or not. That will be a start.
[Re: Alaskan_TA]
#1198525
03/18/12 01:30 AM
03/18/12 01:30 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
That is just a random photo that I have collected..
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#1198526
03/18/12 01:33 AM
03/18/12 01:33 AM
Troy
West Coast, CA
With all of this being said....is there anyway by looking at a dash VIN number can you figure out if that car should have the dimples?
[Re: Troy]
#1198528
03/18/12 01:53 AM
03/18/12 01:53 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Nope.
[Re: Troy]
#1198529
03/18/12 02:07 AM
03/18/12 02:07 AM
6bblgt
Las Vegas, NV
Hi Scott, Hope all is well.
The Hemi car picture I posted had a date of 808 and there are no dimples. I have been looking and many cars recently and I can't find and clear cut date on when these were used.
are you sure that's not B08?
[Re: 1_WILD_RT]
#1198532
03/18/12 02:50 AM
03/18/12 02:50 AM
6bblgt
Las Vegas, NV
My old R/T SE has a SPD of 723 & does not have the dimples... I guess it's suspect.....
I was trying to point out that there is some rhyme/reason and/or pattern to the dimple vs. no-dimple. The "maybe" period could be the last 3 months of the year. Your "former" car could be the lone exception for the end of July '70, or the last month of production might all be without.
My 702 SPD '70 Challenger R/T was finished at least 2 weeks late. It has many '71 attributes. My 801 SPD '71 Barracuda was assembled at least 2 months early. It has many '70 attributes.
[Re: Troy]
#1198533
03/18/12 02:52 AM
03/18/12 02:52 AM
6bblgt
Las Vegas, NV
I have three pictures of the tag and they all look like 808. I don't know if you saw this car Dan. It was that survivor Hemi Challenger that showed up late at the last Spring Fling. Very cool car!!
Yes, and it's B08.
[Re: 6bblgt]
#1198534
03/18/12 03:09 AM
03/18/12 03:09 AM
Troy
West Coast, CA
ok..... I must have three real bad pictures. I would email you my photos but it does not seem to work.
[Re: Alaskan_TA]
#1198537
03/18/12 10:24 AM
03/18/12 10:24 AM
Posts: 11,022 Farmington, CT
KISSAlien
Farmington, CT
The SPD on my pink car is 324 but the door mylar is 4-70. It has the dimples.
