Re: I bet I'm the 1st to ever do this!
[Re: Mad Dart]
#1198302
03/18/12 10:54 AM
03/18/12 10:54 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Not a bad idea on the screens......just in case..or any other stuff from falling down there....like lash caps, broke rockers and such.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: W.I.N. Racing]
#1198303
03/18/12 12:10 PM
03/18/12 12:10 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
Something similar used to be done on "B" blocks so Hemi Heads could be used on them...
The "B" block I saw was at Bartons, looked like the bosses were brass welded (brazed) on.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: slippery440]
#1198305
03/18/12 12:25 PM
03/18/12 12:25 PM
Posts: 1,532 off the grid
340B5
off the grid
Even if the lugs would break, they should stay on the bolt. Maybe a little loctite? I welded one of my iron heads, and the weld was to tough, the machinist couldn't cut it. I had to use a grinding stone myself to machine it.
Yeah, it's got a smallblock.
