Re: I bet I'm the 1st to ever do this! [Re: Mad Dart] #1198302
03/18/12 10:54 AM
03/18/12 10:54 AM
north cakalaky
I
instigator Offline OP
I
north cakalaky
Not a bad idea on the screens......just in case..or any other stuff from falling down there....like lash caps, broke rockers and such.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: I bet I'm the 1st to ever do this! [Re: W.I.N. Racing] #1198303
03/18/12 12:10 PM
03/18/12 12:10 PM
Byron, NY
W.I.N. Racing Online content
W.I.N. Racing  Online Content
Byron, NY
Something similar used to be done on "B" blocks so Hemi Heads could be used on them...
The "B" block I saw was at Bartons, looked like the bosses were brass welded (brazed) on.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: I bet I'm the 1st to ever do this! [Re: Mad Dart] #1198304
03/18/12 12:13 PM
03/18/12 12:13 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
I think I still have that magazine article covering Charlie Malyuke's modifications--if I remember correctly, he used a silicon-bronze weld process.
I am sure it will hold since them extra Studs/Nuts are only going to be torqued to 45lbs. You only need enough so you don't pop a lung!!
They may hold up to the 45 pounds of torque but how about the pressure when he puts the boost to it and the heads try to lift off the block?
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: I bet I'm the 1st to ever do this! [Re: slippery440] #1198305
03/18/12 12:25 PM
03/18/12 12:25 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Even if the lugs would break, they should stay on the bolt. Maybe a little loctite? I welded one of my iron heads, and the weld was to tough, the machinist couldn't cut it. I had to use a grinding stone myself to machine it.
Yeah, it's got a smallblock.
Re: I bet I'm the 1st to ever do this! [Re: slippery440] #1198306
03/18/12 01:29 PM
03/18/12 01:29 PM
north cakalaky
I
I
north cakalaky
The bolt is stretched to tension, just like a rod bolt, which is exerting most of it's elastic force already, if put onder much more stress, then the bolt will fail.
65 Barracuda
Re: I bet I'm the 1st to ever do this! [Re: instigator] #1198307
03/18/12 02:06 PM
03/18/12 02:06 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think a key factor will be whether or not the blocks are high enough to be machined flush to the deck. If they sit even slightly below the deck then torquing the bolts will put undue stress on them. If they're machined flush then they'll only be pulled up against the gasket/head.
