Ld 340 flow bench test results #1197021
03/14/12 04:30 PM
03/14/12 04:30 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
A good Friend of mine asked me if I would check his LD 340 on my flow bench today and I myself was a little curious so I mounted a small block edelbrock to the bench and did a flow test on the head. We then bolted his some what grubby looking intake to the head. This was a used intake that was never touched with a grinder so it was not even gasket matched. Here are the flow numbers.
head head with intake
100 60 62
200 137 130
300 200 187
400 251 224
450 256 239
500 267 247
550 273 249
600 275 254
650 276 255
700 276 255
I always knew that these were good intakes and after doing this test it backs up what we have seen at the track for years. He wants to see the results from Matt's Victor 340 intake and if they are close we will do some gasket matching and touch up work to the LD340. Here are a couple of pictures of his intake so you can see how much better it could be with some work.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Ld 340 flow bench test results [Re: pittsburghracer] #1197022
03/14/12 04:36 PM
03/14/12 04:36 PM
organ
maximum entropy Offline
organ
wow, that is good. no wonder my old 340 ran so good. interesting.
Re: Ld 340 flow bench test results [Re: pittsburghracer] #1197023
03/14/12 08:25 PM
03/14/12 08:25 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
That is pretty good, especially for a dual plane intake.
Did you tape up the 7 unused ports for the test?
Re: Ld 340 flow bench test results [Re: S/ST 3040] #1197024
03/14/12 09:14 PM
03/14/12 09:14 PM
PA.
"Little"John
"Little"John
PA.
I always just stuff red garage rags in all the other ports out of the plenum flow path. I like to play with open and 4 hole adapters mounted on top but they were all in use today. I know the LD340 has always been a good intake but I was still surprised by the numbers especially with it not being at least gasket matched. In that one picture you can see his old gasket mark. Matt had his victor in his car today so I couldn't try it but I will try to update this with those numbers tomorrow.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Ld 340 flow bench test results [Re: pittsburghracer] #1197025
03/15/12 03:43 AM
03/15/12 03:43 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
I'd love to see the numbers with the plennum divider milled out of it.
Re: Ld 340 flow bench test results [Re: Mcode69] #1197026
03/15/12 08:42 AM
03/15/12 08:42 AM
PA.
"Little"John
"Little"John
PA.
I just sold a used one a few months ago to one of our members that I had laying here for years. Whoever owned it before me cut the plenum out and then welded it back in. Here's a picture of the manifold before I sold it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Ld 340 flow bench test results [Re: pittsburghracer] #1197027
03/15/12 10:07 AM
03/15/12 10:07 AM
Delray beach, Florida
P
Performance Only Offline
P
i'm scratching my head wondering why you guys think losing 20-30 cfm through the manifold are good numbers?
machine shop owner and engine builder
Re: Ld 340 flow bench test results [Re: pittsburghracer] #1197028
03/15/12 10:13 AM
03/15/12 10:13 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I'd be curious what a stock 69-70 340 avs intake would flow and compare the two. All the reading I've done over the years says the stock manifold was pretty good right out of the box, and that the ld340 was really just a copy in aluminum - 5 HP at best over the stock intake. Same goes for the current aluminum dual plane MP offers for the small block - it too looks like an aluminum copy of the factory cast iron avs intake.
Re: Ld 340 flow bench test results [Re: Performance Only] #1197029
03/15/12 10:47 AM
03/15/12 10:47 AM
PA.
"Little"John
"Little"John
PA.
Dan this intake was not even gasket matched. Every intake I have tested has picked up 10+ cfm just by doing that. Flow a small block super victor sometime if you really want to see a piece of crap. I bolted a small block chevy victor jr. to a set of Dart platinum heads I ported and the numbers dropped from 300cfm to 260 and the chevy guys love that intake.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Ld 340 flow bench test results [Re: Sixpak] #1197030
03/15/12 10:49 AM
03/15/12 10:49 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
LD340's are not at all a copy of a stock intake.
Ive picked up over 1mph going fromm a ported stock TQ intake to a gasket matched LD340.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Ld 340 flow bench test results [Re: Rapid340] #1197031
03/15/12 12:16 PM
03/15/12 12:16 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Brian did that same test with an RPM and SV and the SV flowed more air. SV made less HP and a bunch less tq on the 408 engine. Guess it's all specific to what you want to do.
http://www.carcraft.com/techarticles/ccrp_1006_small_block_mopar_stroker_dyno_test/index.html
I like the old LD intake.
Re: Ld 340 flow bench test results [Re: RobX4406] #1197032
03/15/12 01:13 PM
03/15/12 01:13 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
John, I have a port mathed victor jr on the shelf.If you need one to try.
Re: Ld 340 flow bench test results [Re: B1MAXX] #1197033
03/15/12 01:41 PM
03/15/12 01:41 PM
PA.
"Little"John
"Little"John
PA.
Not if its a chevy. I have (4) 2975's and (1) 2999
I have been buying used ones, porting them and selling them. I am finding out that you can buy that used chevy stuff real cheap and after a little work its pretty easy so resale.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Ld 340 flow bench test results [Re: pittsburghracer] #1197034
03/15/12 01:59 PM
03/15/12 01:59 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
No, its for standard port small mopar...
Re: Ld 340 flow bench test results [Re: pittsburghracer] #1197035
03/15/12 02:09 PM
03/15/12 02:09 PM
P
P
okay, i see what your saying. the ld340 is better than some of the other intakes. i'll buy that. the ports in that manifold are tiny, so velocity is high, but the flow still stinks IMO, even after gasket matching. for the right combo there'd be an obvious gain over stock, but that intake will only get you just so much.
glad you flowed it and alway's enjoy seeing results like the ones you posted.
Re: Ld 340 flow bench test results [Re: Performance Only] #1197036
03/15/12 03:08 PM
03/15/12 03:08 PM
P
Paul_Fancsali Offline
P
Over .12 in qtr over stock intake and a new M1 dual plane. But the divider was milled down. Check the heights on a stock intake and M1 dual plane the LD is hands down better. You really want to slow down use a performer dual plane Bought one new years ago and gave it away after trying to salvage my money on this mistake 318 Maybe 340-360 hell no
Re: Ld 340 flow bench test results [Re: Paul_Fancsali] #1197037
03/15/12 05:47 PM
03/15/12 05:47 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I dont belive that flow is that important on an intake. Shape and being equal is more important
Re: Ld 340 flow bench test results [Re: pittsburghracer] #1197038
03/15/12 07:41 PM
03/15/12 07:41 PM
S/ST 3040 Offline
S/ST 3040  Offline
I've flowed heads a good bit with intakes and carburetors.
Here's an example of a ported OEM SB head w/Victor 340
and Holley 750.
................HEAD.............W/IN&CARB
.100"______63.8__________63.8
.200"_____134.7_________134.5
.300"_____193.8_________190.7
.400"_____244.2_________233.3
.500"_____257.4_________240.3
.550"_____258.4_________243.4
.600"_____260.1_________245.5
Intake had a good port match and minor work in the plenum.
Re: Ld 340 flow bench test results [Re: pittsburghracer] #1197039
01/15/13 11:39 AM
01/15/13 11:39 AM
PA.
"Little"John
"Little"John
PA.
100 60 62
200 137 130
300 200 187
400 251 224
450 256 239
500 267 247
550 273 249
600 275 254
650 276 255
700 276 255
Just a little update on the LD340. It peters out early and hard. I am finishing up a set his set of open chamber Edelbrocks (2.08 valve) and we didn't push as hard as we could have as he is only going to ran a 520 racer brown cam (1.6 rocker app 550). I wanted him to go with a Victor 340 but he wanted to see what the LD340 would do so I gasket matched it, a little plenum work, and a matched 4150-4500 carb adapter. There is not alot you can do in the runners as you can't even see them. Here are some new numbers.
with out intake-----with intake
.200---137-----------134
.300---198-----------193
.400---245-----------241
.450---268-----------250
.500---279-----------263
.550---289-----------272
.600---290-----------272
.650---292-----------271
.700---302-----------271
I have him talked into trying a Victor.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Ld 340 flow bench test results [Re: pittsburghracer] #1197040
01/15/13 12:00 PM
01/15/13 12:00 PM
Weddington, N.C.
Streetwize Online content
Streetwize  Online Content
Weddington, N.C.
Vic,
Have you ever tested a Victor 340 on a 300-ish @.600 flowing head? Just curious.
WIZE
In Car:
