1970 440x6 intake? #1196437
03/13/12 04:40 PM
03/13/12 04:40 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, school me on the factory six pack intake for 1970. Were they all cast iron? When or did the factory offer an aluminum six pack intake? Also were the 70 exhaust manifold special for a six pack motor? Or were any 70 bb manifolds correct? Thanks again for all the help
Re: 1970 440x6 intake? [Re: 70VcodeCoronetRT] #1196438
03/13/12 05:11 PM
03/13/12 05:11 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
supposibly, some early 1970 lynch road cars recieved aluminum intakes, other wise A12 cars only had them. the exhaust manifolds are different and have no previsions for heat stove.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 1970 440x6 intake? [Re: mopars_1] #1196439
03/13/12 05:57 PM
03/13/12 05:57 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
There is a mixture of aluminium and cast iron up until IIRC November 1969. After that it's all cast iron.
The exhaust manifolds have the provisions for the heat stove, they are just not drilled and tapped I believe.
Re: 1970 440x6 intake? [Re: Morty426] #1196440
03/13/12 09:30 PM
03/13/12 09:30 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
hmm.. Ill have to double check the ones I have. seems like they didn't even have the stand offs for it.
1937 Plymouth PT50
Re: 1970 440x6 intake? [Re: mopars_1] #1196441
03/13/12 09:53 PM
03/13/12 09:53 PM
Alabama
BigMoneyLewis Offline
Alabama
All 70-71 440 hp exhaust manifolds will have the stands for the heat stove I do believe . Otherwise people would be selling "six pack" exhaust manifolds , and I have never heard that term in 40 years .
Greg
gregward@mchsi.com phone 256-852-0955
Re: 1970 440x6 intake? [Re: BigMoneyLewis] #1196442
03/13/12 10:26 PM
03/13/12 10:26 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Do those go on the 440 Hemi?
Re: 1970 440x6 intake? [Re: mopars_1] #1196443
03/13/12 10:31 PM
03/13/12 10:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
incorrect , same exh manifolds , they left off the heat stove .
Re: 1970 440x6 intake? [Re: Morty426] #1196444
03/13/12 10:33 PM
03/13/12 10:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I can't imagine them not drilling and tapping them , the factory had no idea how many 6pk engines would be built in the next 2 years ....
Re: 1970 440x6 intake? [Re: JohnRR] #1196445
03/13/12 10:36 PM
03/13/12 10:36 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
My early Los Angeles Road Runner had an aluminum six bbl intake
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 1970 440x6 intake? [Re: JohnRR] #1196446
03/13/12 11:05 PM
03/13/12 11:05 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
I stand corrected
1937 Plymouth PT50
Re: 1970 440x6 intake? [Re: BloFish] #1196447
03/13/12 11:11 PM
03/13/12 11:11 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
My Hamtramck Cuda, built early Oct, came with an aluminum. A local Lynch Rd RR, built about the same time, has an aluminum.
Re: 1970 440x6 intake? [Re: B5 Bee] #1196448
03/14/12 12:24 AM
03/14/12 12:24 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
As far as I am aware the exhaust manifolds (2951865 & 2899879) were all the same. The 2951865 DS manifold was drilled and tapped for the heat stove in all cases. Only the 440-6 pack & any fresh air N96 package cars did not receive the heat stove.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 1970 440x6 intake? [Re: BloFish] #1196449
03/14/12 01:36 AM
03/14/12 01:36 AM
USA
rftroy Offline
rftroy  Offline
USA
My Los Angeles 440+6 Roadrunner also has an aluminum manifold, with correct cast in part number style. Scheduled Production date Dec. 9, 1969. I've owned it since May 1975.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: 1970 440x6 intake? [Re: rftroy] #1196450
03/14/12 01:15 PM
03/14/12 01:15 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Bob
My scheduled production date was Dec. 8th. 1969
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 1970 440x6 intake? [Re: 70gtx440dana] #1196451
03/14/12 05:45 PM
03/14/12 05:45 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
yes
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 1970 440x6 intake? [Re: BloFish] #1196452
03/15/12 09:03 AM
03/15/12 09:03 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Bob
Engine assembly dates might be the best way to determine the time frame of '70 aluminum intake cars.
My Cuda SPD is Oct 12, motor is Oct 7.
Over the years I've heard there was a supply shortage of the iron intakes and left over '69s were used. Anyone know the real reason?
Re: 1970 440x6 intake? [Re: B5 Bee] #1196453
03/15/12 10:49 AM
03/15/12 10:49 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Always heard the opposite,that Aluminum manifolds were the stock in short supply, and that was the reason Chrysler tooled up in iron, and whatever Aluminum Edelbrock supplied was either used up in production, or went to service (NOS)
....in 1970 Edelbrock was also burdened with suppling over 5000 340 T/A manifolds to Chrysler
Re: 1970 440x6 intake? [Re: DAYCLONA] #1196454
03/16/12 01:31 PM
03/16/12 01:31 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Yes, the iron intake came about to avoid shortages from the expected increased 440-6 production when it was to be offered in models other than the RR and Bee. If the engine assembly plants had to use aluminum intakes on some of the '70s motors, there must of been a shortage of the iron intakes.
I've heard two stories for the iron shortage.
One was they just couldn't produce iron intakes fast enough for the '70 440-6 boom and had shortages the first part of the year.
The other was a shortage due to casting flaws with the iron developing pin holes in some of the castings.
Re: 1970 440x6 intake? [Re: 70VcodeCoronetRT] #1196455
03/17/12 12:33 AM
03/17/12 12:33 AM
phx
metalgod Offline
metalgod  Offline
phx
i have a 70 cuda with a stock factory 6 pack intake that is aluminum also sold a 70 six pack bee to a friend 2 owners also had a aluminum intake
Re: 1970 440x6 intake? [Re: metalgod] #1196456
03/17/12 10:46 AM
03/17/12 10:46 AM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
So would a October build most likely have aluminum? And were the part numbers the same for both?
