8.75 gear oil capacity #1195263
03/11/12 07:50 PM
03/11/12 07:50 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
How much gear lube should a completely dry 8.75 rearend need to fill it to the proper level?
Re: 8.75 gear oil capacity [Re: flatiron] #1195264
03/11/12 07:52 PM
03/11/12 07:52 PM
Kirkland, Washington
Pacnorthcuda Offline
Its well over two quarts but under three. Figure 2.75.
Re: 8.75 gear oil capacity [Re: Pacnorthcuda] #1195265
03/11/12 08:05 PM
03/11/12 08:05 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Ok thanks I just put 2 in and was wondering when a little should be dribbling out the filler hole...Also maybe I should add it's a spool with green bearings in a 72 Dart
Re: 8.75 gear oil capacity [Re: flatiron] #1195266
03/11/12 10:20 PM
03/11/12 10:20 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
2.2 comes to mind, but I AM old...
Re: 8.75 gear oil capacity [Re: flatiron] #1195267
03/11/12 11:57 PM
03/11/12 11:57 PM
don't fill it to the hole when cold Fill it so it is 1/2 to 1 inch below the hole cold Mopar drag techs. use to say to run one quart only of gear oil in a drag car, Dana 60 or 8 3/4. Thier explanation was that the rest of the lube was to quieten down the rear end gear noise in passenges cars with mufflers on
Re: 8.75 gear oil capacity [Re: Cab_Burge] #1195268
03/12/12 06:13 AM
03/12/12 06:13 AM
BDW Offline
BDW  Offline
Re: 8.75 gear oil capacity [Re: BDW] #1195269
03/12/12 06:03 PM
03/12/12 06:03 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Thanks guys I have almost 2 quarts in it guess I'll stop there till warm weather and I make a few passes.
Re: 8.75 gear oil capacity [Re: flatiron] #1195270
03/14/12 01:01 AM
03/14/12 01:01 AM
Missouri
Clayton Offline
Clayton  Offline
Missouri
I just filled mine yesterday and with the bottle of friction modifier in it it started to run out the fill hole just before the seconed quart was all in, had about an inch and a half left in the bottle.
