XV Radiator. Anyone try them yet? #119368
09/11/08 05:09 PM
09/11/08 05:09 PM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
Anyone try their system yet. My only concern is the higher speed flaps sections seem small. I will be running a 6.1 crate, w/air cond. in the '71 RR.
http://www.xvmotorsports.com/products/de...20Engine%20Swap
Re: XV Radiator. Anyone try them yet? [Re: Fasbird] #119369
09/11/08 06:06 PM
09/11/08 06:06 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
No, but judging from the pictures, there may be a few issues...
1) The passenger side mount looks like it might require some trimming on the frame rail tabs, since it looks like the mount edge is flush with the end caps of the radiator.
2) The radiator overflow bottle will almost certainly interfere with the washer bottle reservoir, necessitating relocation/replacement of the washer bottle.
3) For non-late hemi engines, the water pump housing will need to be passenger-side outlet.
4) That price even makes TTI headers look cheap!
-Marq
Re: XV Radiator. Anyone try them yet? [Re: Fasbird] #119370
09/11/08 06:57 PM
09/11/08 06:57 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've been looking into radiators too for mine...was thinking about a dual pass alloy one like that too...think you could put something together for far less cost...Just assuming you don't mind making some brackets and what not?
XV is sure not shy about thier pricing though
Re: XV Radiator. Anyone try them yet? [Re: Fasbird] #119371
09/12/08 08:44 AM
09/12/08 08:44 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
We have made copper/brass radiators for the 6.1l Hemi's for Dayclona and Keisler and they have had good results. I guess it's just about how you want it to look. (a/l vs c/u) They can also be made for less than the a/l ones. Unless you want part #'s on the top tank.
Bob Schirmer
Glen-ray Radiators
1.800.537.3775
1.715.842.3352
Re: XV Radiator. Anyone try them yet? [Re: OzHemi] #119372
09/12/08 09:49 AM
09/12/08 09:49 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Give US Radiator down in the high deserts of Southern California a call. They built me a radiator & shroud/electric fan combo for a very reasonable price. The design was based on my horsepower & application etc. It looks almost original, but it is thicker and cools way better.
Re: XV Radiator. Anyone try them yet? [Re: radiatorman] #119373
09/12/08 10:25 AM
09/12/08 10:25 AM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
Hey Bob,
I spoke with you at the Nats this year. I saw your radiator for this application in Gary Beineke's car. I would be looking for a "Plug and Play" setup, so we would have to talk about recommended fan module setup also. I am running the new EFI 6.1 crate/425HP with supplied MP EMS. I am DEFINITELY running Air Conditioning. I do not need numbers on the tank
Note; you also told me to get you the numbers off my 22" original tank, as you may have a need for it. And, it may give me a discount by trading it in to you. right?
Re: XV Radiator. Anyone try them yet? [Re: Fasbird] #119374
09/12/08 02:33 PM
09/12/08 02:33 PM
the house on the left.
cogen80 Offline
cogen80  Offline
if you look around the net you can probably find that exact set up cheaper. XV seems to do a very good job of taking someone elses product, slapping their stickers on them and marking up the price .
