MOST FLOW OUT OF A SET OF -1S #1193631
03/08/12 08:48 PM
03/08/12 08:48 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
what is the most you have seen?
Re: MOST FLOW OUT OF A SET OF -1S [Re: Randy..] #1193632
03/08/12 09:29 PM
03/08/12 09:29 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
i think the highest number I have seen was in the 380s
Re: MOST FLOW OUT OF A SET OF -1S [Re: joshking440] #1193633
03/08/12 09:34 PM
03/08/12 09:34 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
440-1s cnc345s 380cfm
1.39 9.85 - 137 mph
Re: MOST FLOW OUT OF A SET OF -1S [Re: Ari440] #1193634
03/08/12 09:53 PM
03/08/12 09:53 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
just wondering, bought a set from a member and flow sheet was 385 at .700, thought that was a killer number for a -1.
Re: MOST FLOW OUT OF A SET OF -1S [Re: Randy..] #1193635
03/08/12 10:12 PM
03/08/12 10:12 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Any ideal on who ported them to get those #'s?
Re: MOST FLOW OUT OF A SET OF -1S [Re: racerx] #1193636
03/08/12 10:17 PM
03/08/12 10:17 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
Slawko Racing
Re: MOST FLOW OUT OF A SET OF -1S [Re: Randy..] #1193637
03/08/12 10:29 PM
03/08/12 10:29 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thaxs one other ? what's the differance between the -1's and the 345's?
Re: MOST FLOW OUT OF A SET OF -1S [Re: racerx] #1193638
03/09/12 12:47 AM
03/09/12 12:47 AM
gregsdart Online content
gregsdart  Online Content
Mine originally flowed 378 at .700 and I think 380 at.800.
I had 2.30 intake valves put in and saw a five to six percent jump in flow, (399 cfm at .800) but ZERO gains.
there was a dip in flow around .400 that may account for part of the lack of gain. The heads flow about the same as before at that point.
I wouldn't worry so much about the ultimate numbers as I would how fast guys are going with them. That is a much better bench mark. My best ET/mph was before the 2.3 valve mods, with a 280/288/110 cam with .765 intake lift. I put a 283/296/112 cam in with .775 lift and got very little if any improvement.
-1 heads are about all done somewhere around 850 to 900 hp, depending on build.
Re: MOST FLOW OUT OF A SET OF -1S [Re: gregsdart] #1193639
03/09/12 01:04 AM
03/09/12 01:04 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Rightly or wrongly I look at average flow from .200 to .600 to compare heads. You are right too many people get hung up on peak .700 or .800 numbers when they aren't runnning enough cam or rpms for that number to matter IMHO.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: MOST FLOW OUT OF A SET OF -1S [Re: d7cook] #1193640
03/09/12 07:10 PM
03/09/12 07:10 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
the car they came off of went 8.30s at 160+ at 3300lbs.
Re: MOST FLOW OUT OF A SET OF -1S [Re: Randy..] #1193641
03/09/12 07:37 PM
03/09/12 07:37 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
You should have bought the whole engine. That sounds like a pretty good combo unless it had some added help.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: MOST FLOW OUT OF A SET OF -1S [Re: Randy..] #1193642
03/09/12 07:41 PM
03/09/12 07:41 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I would try and copy the engine that the heads come off of as close as possible.Also might be a good idea to find out what converter & gear ratio he was using.
PS It's nice to see more Mopars showing up in AlaBama!!!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: MOST FLOW OUT OF A SET OF -1S [Re: Randy..] #1193643
03/09/12 09:27 PM
03/09/12 09:27 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
Unlikely without nos, boost or being dropped out of a plane, as stated above they are a good head with alot of work to 850 + hp but have practical limitations beyond that
would take upwards of 1150 hp to run those numbers
76 Duster work in progress
Re: MOST FLOW OUT OF A SET OF -1S [Re: Edge] #1193644
03/09/12 09:53 PM
03/09/12 09:53 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
single fogger. and i am putting twin 75mm turbo's on them.
Re: MOST FLOW OUT OF A SET OF -1S [Re: Randy..] #1193645
03/09/12 09:58 PM
03/09/12 09:58 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Guppys heads...
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: MOST FLOW OUT OF A SET OF -1S [Re: 1967dartgt] #1193646
03/09/12 10:06 PM
03/09/12 10:06 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
Re: MOST FLOW OUT OF A SET OF -1S [Re: Randy..] #1193647
03/09/12 10:11 PM
03/09/12 10:11 PM
PA.
"Little"John
"Little"John
PA.
I thought so. People often forget to mention the power adders.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: MOST FLOW OUT OF A SET OF -1S [Re: pittsburghracer] #1193648
03/09/12 11:28 PM
03/09/12 11:28 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
Yeah and people forget to say that their 2300lb chassis car can't run 8.30'S n/a either let alone drive it down to the local drive in legally if wanted to....I never see anyone running down your daytona chassis car because it's not super fast,so why do you jump at every chance to run down power adder cars Sorry for the hyjack to OP...
Re: MOST FLOW OUT OF A SET OF -1S [Re: Gary Robbins] #1193649
03/10/12 01:30 PM
03/10/12 01:30 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
N/A my 557ci made 955hp (Methanol injection)w/ 345cc CNC'd -1's that flow 382 at .800 these are Jeff's from Modern's program.
Cam is .875" (less lash and deflection)so i am opening them up as far as reasonable
Car weighs 2,850 and at 4,000 foot DA ran 8.80's, but there is more left in the combo...
If you want more than that N/A you need a better head IMO.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: MOST FLOW OUT OF A SET OF -1S [Re: Gary Robbins] #1193650
03/10/12 04:13 PM
03/10/12 04:13 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Power adders are todays racing!! Just the way it is. When the street cars are a full second or two faster than dedicated race cars what option is there? Index class or get with the rest (Non Mopar)people as that is what they are doing. Iam still trying to figure out why the forum on here was done away with. Dont matter what (Mopar Type head) you buy,You wont compete with the rest all out.Weight? doesnt seem to matter as much when you see 3800 Lbs cars running 7.30's same as the pipe racks, now does it? Twin Turbo's Heck yes your 1's will be faster than the rest !
