Re: Synthetic oil questions............... [Re: Thumperdart] #1193611
03/09/12 05:19 PM
03/09/12 05:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use 5W-30 Mobile 1 and mix it with 15W-50 Mobile 1
to get the hot pressure I want at the end of a run
Re: Synthetic oil questions............... [Re: MR_P_BODY] #1193612
03/09/12 05:42 PM
03/09/12 05:42 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
When its on sale I use 15w 50 Napa synthetic oil with a bottle of Redline zinc additive. Normally I use non synthetic 25w 50 racing pennzoil.
Re: Synthetic oil questions............... [Re: WheelsUp73] #1193613
03/09/12 06:24 PM
03/09/12 06:24 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
VALVOLINE VR1 SYNTHETIC. Man this stuff is slippery. 10 W 40 for us. I believe I can tell a difference in how the motor revs up when I have this stuff in it. It just seems to respond quicker and feels smoother.
Old Geezer Racing
Re: Synthetic oil questions............... [Re: SCATPACK 1] #1193614
03/09/12 06:57 PM
03/09/12 06:57 PM
Guitar Jones Offline
There is at least a 200 RPM difference in idle speed on my engine from mineral to synthetic.
Re: Synthetic oil questions............... [Re: Guitar Jones] #1193615
03/10/12 02:08 AM
03/10/12 02:08 AM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
Always broke my motors in and first couple of trips to the track on Shell Rotella then switched to Mobile 1 15-50. 15 years and 3 engines I only had to put in new bearings once in one (the stroker) and one timing chain and the only part that I ever lost was 1 alum roller rocker, probably out lived itself. Mobile 1, in my opinion, is as good as most any out there. The best oil on the planet cannot replace quality machine work though.
Re: Synthetic oil questions............... [Re: StrokerPost] #1193616
03/10/12 04:19 AM
03/10/12 04:19 AM
Edmonton alberta Canada
mr. 63plymouth Offline
Joe Gibbs baby!!!!! XP3 all the way!!!!!!
461 small block pump gas N/A deal, shifting at 7800 all day with street clothes with 10" tire! Best ET. 9.52 and 142.88 in 68 barracuda!
Re: Synthetic oil questions............... [Re: StrokerPost] #1193617
03/10/12 04:53 AM
03/10/12 04:53 AM
gregsdart Offline
gregsdart  Offline
If you have bearing clearances that are on the race side,(.025 or more) I would stick with a good race 20x50 or race syn 15x50. Thump you drive on the street and do hammer it once in a while, so your oil will be warm and need the higher viscosity to protect the bearings.
Thats assuming you have the .025 or more clearance in the motor. Tighter than that and I would call the oil manufacturer for their recommendations. As a side note, the new Mustang Shelby engine requires a 5w50. I am betting the wide spread is to accommodate tight bearing clearances for warm up and the high power level at running temps.
Re: Synthetic oil questions............... [Re: gregsdart] #1193618
03/10/12 12:50 PM
03/10/12 12:50 PM
State of confusion
Thumperdart Offline OP
State of confusion
Yes Greg my clearances are in the .025-.030 area but even the Valvoline 5w30 has excellent pressures when hot and in the past it was good w/10w30 Royal Purple syn. oils I tried. After I leak the motor down, I`ll try Mobile-1 in the 10w30 range and go from there. Are you still out here?
Re: Synthetic oil questions............... [Re: Thumperdart] #1193619
03/10/12 06:02 PM
03/10/12 06:02 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
10/40 Royal purple here. great purple oil.
Re: Synthetic oil questions............... [Re: Chassisman] #1193620
03/10/12 07:32 PM
03/10/12 07:32 PM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
Quakerstate 5/40 synthetic from 1999 to 2010
Lucas Oil 10/30 in the new engine also synthetic
No problems at all.
Only in my race engines.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Synthetic oil questions............... [Re: Thumperdart] #1193621
03/10/12 09:07 PM
03/10/12 09:07 PM
AZ
Y
yfdcap Offline
yfdcap  Offline
Y
AZ
How many of you run it and what brand please. Was thinking about 10w30 Mobile-1.............
What cam you runnin? Flat tappet?
Re: Synthetic oil questions............... [Re: Thumperdart] #1193622
03/10/12 10:36 PM
03/10/12 10:36 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
I use BRADD PENN oil in my B1
its 10w30 and has all the zinc in it that they(government)took out of
reg oils.
i get it here in dayton,ohio from a bulk oil company--i buy it by the case for like 4.80 a quart.
So, is it just crude oil w/additives or syn?
To help answer your question, is it synthetic ? here is a picture with desciption of the oil I use. Hope this helps.
Ken
Re: Synthetic oil questions............... [Re: krw71ragtop] #1193623
03/11/12 01:22 PM
03/11/12 01:22 PM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
Penzoil 10w30 Synthetic for the last 14 years.
Why does divorce cost so much? Because it is worth it!!!!!
Re: Synthetic oil questions............... [Re: yfdcap] #1193624
03/11/12 01:43 PM
03/11/12 01:43 PM
State of confusion
State of confusion
Solid roller...........
Re: Synthetic oil questions............... [Re: Thumperdart] #1193625
03/11/12 03:29 PM
03/11/12 03:29 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
any diesel oil had all the stuff they took out for car oil.
i run the 1300 15/40 oil. the first couple of changes i put in the zinc goop to help it out.
Re: Synthetic oil questions............... [Re: dmking] #1193626
03/11/12 04:56 PM
03/11/12 04:56 PM
Locomotion Offline
Locomotion  Offline
They've been taking zinc out of many diesel oils as well. It's not easy keeping up with what has how much unless it's obviously advertised. There are some oils for 2007 and newer diesels. Their catalytic converters are part of the reason they took sulfer out of the fuel also.
Re: Synthetic oil questions............... [Re: dmking] #1193627
03/11/12 07:12 PM
03/11/12 07:12 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
15W40 diesel dino oils are about 1,200 ppm zinc these days. The synthetics are a bit higher.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Synthetic oil questions............... [Re: Junky] #1193628
03/11/12 07:26 PM
03/11/12 07:26 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
last time i went on line and compaired brad pen oil zinc and the phosphers amount to rotella and the 1300 it was a tad less or real close and to me not worth the extra price.
that would be bradpenn regular oil
Re: Synthetic oil questions............... [Re: dmking] #1193629
03/12/12 06:04 PM
03/12/12 06:04 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My is if you still intend to drive it everywhere on the street like you did pre-rebuild, don't put anything thinner than a 10W40 in it. Spend some time looking at how the xW30 wts thin out at the operating temps that street cars see, plus check out their low(er) HTHS (Hi Temp / Hi Shear) ratings. HTHS #s have shown a strong correlation between higher #s and better protection in hi-stress components of the engine.
Re: Synthetic oil questions............... [Re: BradH] #1193630
03/12/12 08:15 PM
03/12/12 08:15 PM
State of confusion
State of confusion
After my new best, I plan to drve the hell out of it and went w/ 10w30 Mobile-1.............
