Re: Synthetic oil questions...............
[Re: WheelsUp73]
#1193613
03/09/12 06:24 PM
03/09/12 06:24 PM
Posts: 1,505 TN
SCATPACK 1
TN
VALVOLINE VR1 SYNTHETIC. Man this stuff is slippery. 10 W 40 for us. I believe I can tell a difference in how the motor revs up when I have this stuff in it. It just seems to respond quicker and feels smoother.
Old Geezer Racing
[Re: SCATPACK 1]
#1193614
03/09/12 06:57 PM
03/09/12 06:57 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
There is at least a 200 RPM difference in idle speed on my engine from mineral to synthetic.
[Re: StrokerPost]
#1193617
03/10/12 04:53 AM
03/10/12 04:53 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you have bearing clearances that are on the race side,(.025 or more) I would stick with a good race 20x50 or race syn 15x50. Thump you drive on the street and do hammer it once in a while, so your oil will be warm and need the higher viscosity to protect the bearings. Thats assuming you have the .025 or more clearance in the motor. Tighter than that and I would call the oil manufacturer for their recommendations. As a side note, the new Mustang Shelby engine requires a 5w50. I am betting the wide spread is to accommodate tight bearing clearances for warm up and the high power level at running temps.
[Re: Chassisman]
#1193620
03/10/12 07:32 PM
03/10/12 07:32 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
Quakerstate 5/40 synthetic from 1999 to 2010 Lucas Oil 10/30 in the new engine also synthetic
No problems at all. Only in my race engines.
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
[Re: Thumperdart]
#1193621
03/10/12 09:07 PM
03/10/12 09:07 PM
Posts: 6 AZ
yfdcap
AZ
How many of you run it and what brand please. Was thinking about 10w30 Mobile-1.............
What cam you runnin? Flat tappet?
[Re: Thumperdart]
#1193622
03/10/12 10:36 PM
03/10/12 10:36 PM
Posts: 892 USA
krw71ragtop
USA
I use BRADD PENN oil in my B1 its 10w30 and has all the zinc in it that they(government)took out of reg oils. i get it here in dayton,ohio from a bulk oil company--i buy it by the case for like 4.80 a quart.
So, is it just crude oil w/additives or syn?
To help answer your question, is it synthetic ? here is a picture with desciption of the oil I use. Hope this helps. Ken
[Re: krw71ragtop]
#1193623
03/11/12 01:22 PM
03/11/12 01:22 PM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
Penzoil 10w30 Synthetic for the last 14 years.
Why does divorce cost so much?
Because it is worth it!!!!!
[Re: dmking]
#1193626
03/11/12 04:56 PM
03/11/12 04:56 PM
Posts: 5,894 Florida
Locomotion
any diesel oil had all the stuff they took out for car oil. i run the 1300 15/40 oil. the first couple of changes i put in the zinc goop to help it out.
They've been taking zinc out of many diesel oils as well. It's not easy keeping up with what has how much unless it's obviously advertised. There are some oils for 2007 and newer diesels. Their catalytic converters are part of the reason they took sulfer out of the fuel also.
[Re: dmking]
#1193627
03/11/12 07:12 PM
03/11/12 07:12 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
15W40 diesel dino oils are about 1,200 ppm zinc these days. The synthetics are a bit higher.
