Re: Stealth Heads --- Rocker Arms
[Re: Viol8r]
#1192871
03/07/12 03:10 PM
03/07/12 03:10 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
At this point I am going to go ahead and order Smith Bros. hardened tempered 5/16 ball and cup pushrods. My open spring pressure is only 350lbs., so its worth it to me to not have to tear the thing down and have the heads clearanced.
I called 440source and they said I should have clearanced them when it was put together. I understand that completely, I am just confused as to why they would build them knowing 3/8 rods don't clear.
I did exactly the same thing except mine are ball/ball. But I agree, they shouldn't need to be clearanced. They should just do it while they are machining them.
With the stock rocker arms it's a little more difficult to tell if there will be an issue because the arms are free to move side to side 1/4" or so. I bolted (mocked) everything together and turned it over a few times to see if they would find a happy place, but they just stayed wherever I placed them, but it seemed to want to stay away from the head if I started it there. I may just clearance them a little just in case.
[Re: bobs66440]
#1192872
03/07/12 03:36 PM
03/07/12 03:36 PM
Posts: 5,163 CT
GTX MATT
CT
What is the preferred method to clearance them?
[Re: GTX MATT]
#1192873
03/07/12 03:58 PM
03/07/12 03:58 PM
Posts: 1,795 Greer, SC
TooMany62s
Greer, SC
I have bad news for you, the 5/16 pushrods may not clear either. At least mine didn't. I learned the lesson the hard way. Cheap and good don't go together. The link bar between two of my 440Source roller lifters broke and wiped out my cam. When I took the valve train apart I found the bearings in most of my 440Source rocker arms were rough and the 440Source rocker shafts were galled. Plus the "hardened tips" on the 440Source valves were showing signs of wear. All of this at less than a few hundred street miles. Do yourself a favor, if you have any other 440Source stuff, replace it now while you still have a chance to sell it to some sucker. The only thing I'm still using is the head castings.
[Re: Viol8r]
#1192876
03/07/12 04:52 PM
03/07/12 04:52 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Guess I got lucky.I run Crane alloy 3/8 and old Sig Erson iron rockers.They just clear with no clearance.Rocky
Chrysler Firepower
