six pack center carb question #1192730
03/07/12 10:08 AM
03/07/12 10:08 AM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
I have a set up I'm rebuilding for my bee on the center carb bowl ther is a lever that has a rubber stopper on the end that covers up a hole in the top of the bowl. What is this for? also the way it sits with the butterflies closed it holds the lever so that this hole is open,this doesent seem right to me. I.ve looke at some other set ups on line but they have a different style bowl that has a piece that bolts to the top of bowl. I'm just confused, at work now so no pics of it.Mabey some one has a pic or able to explain if this is right. thanks for any info. ozz
Re: six pack center carb question [Re: ozz383] #1192731
03/07/12 11:32 AM
03/07/12 11:32 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
it's a bowl vent. there's no problem setting it up per spec.
Re: six pack center carb question [Re: lewtot184] #1192732
03/07/12 11:45 AM
03/07/12 11:45 AM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
So its supposed to be open at idle and closed at W/O throttle? and does anyone know the spec or adjustment? Thanks
Re: six pack center carb question [Re: ozz383] #1192733
03/07/12 11:53 AM
03/07/12 11:53 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Mine closes at part throttle...just off idle.
Joe
Re: six pack center carb question [Re: ozz383] #1192734
03/07/12 12:06 PM
03/07/12 12:06 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
There are three different bowls,one with no vent,vent with tube and this one,probably what you have,closed at any point off idle is correct.
Re: six pack center carb question [Re: 62maxwgn] #1192735
03/07/12 12:15 PM
03/07/12 12:15 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Mine is plugged off with a tiny brass plug. Scott told me its fine that way
Re: six pack center carb question [Re: ozz383] #1192736
03/07/12 12:24 PM
03/07/12 12:24 PM
Shoreline, Washington
72roadrunnergtx Offline
Here's a old thread with some details on the purpose of the bowl vent valve as it was designed, including some varying ideas on reverse engineering.
BTW, all stock Chrysler built cars with Holley six-packs had one of the two bowl vent valve styles.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: six pack center carb question [Re: 72roadrunnergtx] #1192737
03/07/12 01:09 PM
03/07/12 01:09 PM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
Thanks guys! It just seemed funny it would be open any time it sets. thanks again ozz
Re: six pack center carb question [Re: 72roadrunnergtx] #1192738
03/07/12 07:22 PM
03/07/12 07:22 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
All but some of the first A12 cars.
